5130 PTO Troubles
/ 5130 PTO Troubles #1
Akwingnut
Wasilla, Alaska
MX110, 5130
While brush hogging grass pto jumped out, and tractor will barely pull itself. Changed filter, now everything works fine except pto, just makes a howl when engaged. Removed from tractor, after checking pressures (260-290psi) to pto clutch pack, pto valve works, can engage clutch pack with 120 psi air pressure. Reassembled, pto is still inoperative. Stumped by this one, anybody have suggestions?
/ 5130 PTO Troubles #2
Since your from Alaska, maybe it is frozen up? Gotta expect something like that from a guy from Florida....
David from jax
Good luck, don't have a clue what could be wrong, but thought maybe bringing it back to the top might help...
/ 5130 PTO Troubles
Finally got it fixed, found pto valve leaking enough that the clutch pack would'nt overcome the brake. Replaced the valve and it works beautiful. So I guess it wasn't froze up afterall.L.O.L.
2013 FORD F-250 SUPER DUTY (A65643)
2013 FORD F-250...
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
2018 ROCK SOLID CARGO 14 T/A SHOWER TRAILER (A65643)
2018 ROCK SOLID...
New/Unused 3 Point Receiver Hitch Attachment (A65583)
New/Unused 3 Point...
SET OF (4) PORT A POTTIES (A65643)
SET OF (4) PORT A...
2007 VERMEER T755 COMMANDER III TRENCHER (A65643)
2007 VERMEER T755...
