Working under a ztr - how?
   / Working under a ztr - how? #1
lhfarm
Central Indiana
NH TC40DA
I have a Snapper ZTR that has developed a fluid leak that is running along the farme. I'm trying to figure out the source and can't see anyting from the top or from looking underneath the engine. I need to get the mower up off the ground enough so I can see what is going on. What is a safe method, both for me and the mower?
I don't have car ramps, but do have a tractor with an FEL. I do have jack stands. Suggestions?
   / Working under a ztr - how? #2
How much does the mower weigh? If I could lift it with my loader I would and then put it on a pair of saw horses or concrete cinder blocks. Can you just prop it up on it's backside?
   / Working under a ztr - how? #3
I lift mine w/ a chain and the hooks on the FEL. I leave the back wheels on the ground, place blocks behind the tires to avoid it rolling back and lift the fron end of the mower up to get underneath.
   / Working under a ztr - how? #4
1*lift the front end of the mower up to get underneath.
1*What keeps it from falling on you when you are under it?
TC710 FINISHING MOWER (A50459)
TC710 FINISHING...
Unused Delta Crash...
2017 Ram 4500 Bucket Truck (A52128)
2017 Ram 4500...
2009 HINO 185 18FT BOX TRUCK (A51219)
2009 HINO 185 18FT...
Loader with IH Brackets (A50515)
Loader with IH...
2021 Doyle 8 Ton Trailer Tender (A52128)
2021 Doyle 8 Ton...
