Rocks in my hay
/ Rocks in my hay #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
I was taking some hay samples and saw this rock in one of my bales. That JD baler will pick up just about anything!
D.
/ Rocks in my hay #2
It is kind of amazing sometimes how big a rock or log a baler will pickup and feed into a bale. The old OMC baler that I had in the 80's that had metal drums/rollers instead of belts would sure make some funny noises when you would get something like that in it while you were tying off a bale.
/ Rocks in my hay #5
Most often those rocks are rolled up by the rake and supported by some hay in the windrow. Try running the rake a little lighter.
/ Rocks in my hay #6
It could have been a skunk. I seem to get a few snakes a year in square bales.
Dan
/ Rocks in my hay
I tightened it up some and it started balling up.
The rock situation is getting better as the grass spreads.
D.
/ Rocks in my hay #8
I know I've baled my fair share of fence posts! 4-5" posts don't even make a sound going through. I used to bale on islands that flood every spring and get covered in driftwood and logs. Lots of sticks in bales there!
/ Rocks in my hay
Wow - that is a story!
D.
/ Rocks in my hay #10
We've found that the rotary rakes don't add rocks and sticks into the windrows as well as the older style rakes with the reels that tend to rope the hay.
We learned this from haylage as the chopper knives don't seem to hold an edge as well with the steady injestion of rocks and stuff found in fields.
/ Rocks in my hay
I have heard the same. I am not sure I can justify the expense of a rotary rake. My rock situation is steadily getting better as the turf improves.
I am using a ground driven wheel rake.
D.
/ Rocks in my hay #12
They are very economical to buy but they to tend to rope the hay which is how the rocks and foreign items can stay in the hay.
The other style makes all the jobs around the hay easier. For the baler when you slow because of overload it doesn't have an extra five foot or more that it is trying to pull in, same for choppers.
I do understand economics and sometimes it is hard to justify.
/ Rocks in my hay #13
*I used to bale on islands that flood every spring and get covered in driftwood and logs.
**Lots of sticks in bales there!
*How did you get the tractor and equip onto the island?
**Was the price per bail less because of this?
/ Rocks in my hay
I will have to check rotary rakes out. I am just happy to be baling my own hay at this point. :)
D.
/ Rocks in my hay #15
I'd take a rock over a skunk ANY DAY! I can remember when I was a kid stacking square bales in the loft and getting one with a skunk in it. PEEEWWWWWWWWWWWW!
/ Rocks in my hay #16
In all the years I have used wheel rakes I have only seen hay "roped" once. A knucklehead who did not have a tedder, used his wheel rake to turn some very,very heavy bermuda 5 or 6 times. The baler would literally pull hay from 20' out in front of the tractor. He baled 4 or 5 bales on one round and drove off and left the whole field.
/ Rocks in my hay #17
First, the island is prime ag land as the silt that is deposited each spring and fall during flooding is rich stuff. There is about 3000 acres of so on the chain of 4 islands. 40 years ago a power dam was built above the islands which meant the low summer water couldn't be guaranteed for driving there. They built a bridge and causeway to connect the main islands. Before this the hay was stored in elevated barns on the island and hauled off using sleds across the frozen river. Diesel tractors were a boon as the gas tractors would die crossing the river. Horses would be used to pull them out.
Second, the price is no less as it is great hay but the fellow I worked for kept the ones with big sticks. You can see them easily on the side of the bale.
The worst part was sometimes whole trees would be in the middle of the field and you'd have to go around or you'd hit pieces of them while mowing.
All the ground is now in row crop as far as I know.
Ken
/ Rocks in my hay #18
When I read the Subject of this thread I knew the problem would be the result of a Wheel Rake!!!
The wheel rake is the biggest detriment to forage quality! The easy nature of their use results in increased Ash content in the forage. However, each grower must assess the trade off between time/investment and producing qualty hay.
We owned a 10 wheel rake in the past, it sure made raking faster, but we could never get it adjusted properly to limit the amount of soil that contaminated the forage. We now have a rotary rake that we can better adjust to gather hay. If someone doesn't adjust the rake properly though you will have dirt in the hay too. But given the fact that the rotary rake is powered by the tractor and not the ground you have better raking.
Jim
/ Rocks in my hay #19
To only roll it over once might just mean that you are only pulling two feet of extra hay!
/ Rocks in my hay
Interesting - almost nobody down here owns a tedder.
D.
