Rocks in my hay
   / Rocks in my hay #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
I was taking some hay samples and saw this rock in one of my bales. That JD baler will pick up just about anything!
D.
   / Rocks in my hay #2
It is kind of amazing sometimes how big a rock or log a baler will pickup and feed into a bale. The old OMC baler that I had in the 80's that had metal drums/rollers instead of belts would sure make some funny noises when you would get something like that in it while you were tying off a bale.
   / Rocks in my hay #5
Most often those rocks are rolled up by the rake and supported by some hay in the windrow. Try running the rake a little lighter.
   / Rocks in my hay #6
It could have been a skunk. I seem to get a few snakes a year in square bales.
Dan
   / Rocks in my hay
I tightened it up some and it started balling up.
The rock situation is getting better as the grass spreads.
D.
   / Rocks in my hay #8
I know I've baled my fair share of fence posts! 4-5" posts don't even make a sound going through. I used to bale on islands that flood every spring and get covered in driftwood and logs. Lots of sticks in bales there!
   / Rocks in my hay
Wow - that is a story!
D.
   / Rocks in my hay #10
We've found that the rotary rakes don't add rocks and sticks into the windrows as well as the older style rakes with the reels that tend to rope the hay.
We learned this from haylage as the chopper knives don't seem to hold an edge as well with the steady injestion of rocks and stuff found in fields.
2017 Ford F-250 Crew Cab Pickup Truck (A51692)
2017 Ford F-250...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
1999 Blaw-Knox PF 161 Paver (A52384)
1999 Blaw-Knox PF...
Used 20' Container Box (A52384)
Used 20' Container...
2016 CATERPILLAR 730C2 OFF ROAD DUMP (A51246)
2016 CATERPILLAR...
Pull-Behind Rotary Brush Cutter PTO Attachment (A51691)
Pull-Behind Rotary...
