Kioti DK35...Good Deal?
/ Kioti DK35...Good Deal? #1
Pozzman
Member
MO
1702 Yanmar
I have been reading the Kioti and Kubota message boards for quite some time trying to decide which tractor is best. The tractor will be used for brush hogging about 7 acres, eventually I hope to put in a half acre/acre garden garden and an acre of grapes and blueberry bushes which will require some future tilling and digging for fence post.
I have also been looking at used Kubota B series and Kioti LK series and missed a couple of good deals the past few weeks. However, I sometimes wonder if a bigger tractor (> than 30hp) would be better.
I have just come across a 2003 Kioti DK35 that I am going to look at tomorrow. The tractor has 205 hrs, 4wd and shuttle shift. It also includes a 60' finish mower, 72" brush hog and disc for $10,500.
From what I have read, those that own a DK35 are very happy with it. My questions are: 1) is this a good price and 2) is there anything I should specifically inspect for in regard to the tractor?
Any input is greatly appreciated.
/ Kioti DK35...Good Deal? #2
Don't you need a front end loader for the tractor? You didn't mention it having one. In my case I would not own a compact tractor without one.
/ Kioti DK35...Good Deal? #3
I have one and like mine. What is the general condition?? How about the attachments what kind of shape are they in??
I would do a good check over and test drive, then make an offer. I would try to guage how bad they want to sell. I would try to get it as cheap as possible cause I am a tight wad.
/ Kioti DK35...Good Deal? #4
I have a DK35 and am pretty happy with it. I have a woods front loader not the kioti one. I have a woods backhoe also. I've used it for brush hogging, tilling, excavating, pulling stumps, etc. Just finished up two 12 hour days excavating around a garage.
I could nit pick a couple things, but overall it's a workhorse. I have a 5ft brushhog that is way too small for it. Should have got a 6 or 7 footer. No real problems after 4 years. It was the best $12,000 I've spent.
I would like to have a FEL but that would probably add $2000 to the cost. Based on my budget I am trying not to to keep it around $9,500 - $10,000, that is why I missed some good buys the past few weeks, over my budget.
In regard to an offer, he was originally asking $11,500, I offered $9,500 conditional on driving it, he countered with $10,500. I figured I'"ll take a look at it and take it from there (only 45 minute drive from where I live). I'll keep you posted.
/ Kioti DK35...Good Deal? #6
I have 900 hours on my 2005 and it has had no major issues. Only issue was a broken seat mount.
I went and looked/drove the tractor it ran great and was in good shape. Engine was clean, no oil leaks. PTO ran fine it handled the 6 ft brush hog with no problem. Oil on the dip stick at the back by the PTO was very clean.
Issues:
It was hard to get in and out of 4wd and accelerator lever on column was very tight (hard to move), I was wondering if this is normal. However, the foot accelerator was fine.
Also the steering wheel had some play.
I think he'll go as low as $10,000. Any thoughts/input?
/ Kioti DK35...Good Deal? #8
The hand operated accelerator is not a problem. mine did the same thing. In the linkage you will see a point where a pin rides inside a fitting, just take a finger and grease that point, that should take care of the problem.
/ Kioti DK35...Good Deal? #9
10K plus the cost of a new loader would put you up to about 12500 I'd guess. That is still a decent price for a very good condition reliable 35hp tractor. If I were you I'd also look around for a two or three year old CK30 with loader which I would think would be at or about that price point. Less PTO power but also a great tractor. The concensus on TBN is that just about everyone needs a loader on a CUT so don't leave that out of your budget.
/ Kioti DK35...Good Deal? #10
Buy a Bobcat ct 230 or 35 they are giving them away at alot of dealers, same tractor as Kioti.
I have heard of 30s and 35s going for around 10k can't beat those deals. call some Bobcat dealers.
/ Kioti DK35...Good Deal? #11
Make sure you check the wiring harness. Electrical problems could be right in front of your eyes.
/ Kioti DK35...Good Deal? #12
another question are you financing or not. If not do the math on the payment. would guess a loan on slightly used one would be 8 Plus rate so the Payment on new may be the same. I just saw bobcat is offering 0% and are giving the loader for free.
Don
/ Kioti DK35...Good Deal? #13
The Bobcat deals ended last week. Kioti is competetive again.
/ Kioti DK35...Good Deal? #14
Issues:
I have a Kioti DK35 that I just bought last week and had it running non-stop this weekend. Pushed down trees, pulled out fences, bushhogged a few acres of grass, graded a driveway and loved it.
I cannont for the life of my get the 4wd to engage. How do you engage the 4wd on a Kioti DK35? I got it as a fluke one time, but was not able to get it going again.
Any help would be much appreciated. I was going to start pushing my trees down but I didnt have the traction.
/ Kioti DK35...Good Deal? #15
Hendy: If the tractor has a FEL, use it to lift the weight off the front wheels, that makes it a lot easier to engage and disengage the 4 wheel drive.
/ Kioti DK35...Good Deal? #16
Mine usually goes into 4-wheel ok, but is hard to get out. I just push the lever down and roll forward a little and I am in 4-wheel drive. To come out of 4-wheel drive I pull up on the handle and roll forward a little and I am out of 4-wheel drive.
/ Kioti DK35...Good Deal? #17
You may need to spray some penatrating oil on the linkage and the shaft where it goes into the transmission.
I engage/disengage the 4 wheel drive while moving and it slides right in and out.
/ Kioti DK35...Good Deal? #18
Those deals have ended.
/ Kioti DK35...Good Deal? #19
I cannont for the life of my get the 4wd to engage. How do you engage the 4wd on a Kioti DK35? I got it as a fluke one time, but was not able to get it going again.QUOTE]
I have a foolproof way that never fails. I come to a complete stop, then push the button. Goes in amd out of 4wd everytime. :D (sorry couldn't resist)
/ Kioti DK35...Good Deal? #20
Pray tell, why do you bother coming to a complete stop? The new DK tractors go into and out of 4wd on the fly quite happily.
John Deere Z997R (A60462)
John Deere Z997R...
2001 Freightliner FLD120 T/A Sleeper Cab Truck Tractor (A61573)
2001 Freightliner...
2019 Nissan Sentra Sedan (A61574)
2019 Nissan Sentra...
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
2012 CATERPILLAR 259B3 SKID STEER (A64279)
2012 CATERPILLAR...
2023 Kubota SVL97-2 Compact Track Loader (A63689)
2023 Kubota...
