your take on this diesel additive test?
   / your take on this diesel additive test? #31
BJN- PS had more wear in my engine then MMO..For me, there is no need for PS; then again I only start at -20 F..
Even my 131 said non-2007 Comp but this is a tractor and you need to play with ratios. Again, for me I would NEVER use PS again based on my UOA. YMMV
So you are saying that using Power Service diesel fuel additive showed increased engine wear in a used oil analysis?
   / your take on this diesel additive test? #32
YMMV
But my oil test said stop using it and UOA came back fine...Done with it.
   / your take on this diesel additive test? #33
Unless your tractor was designed for ULSD Fuel why are you guys not running Off-Road diesel in them?, For my Kubota it says right in the manual to use #2 fuel in it, plus in WV off road fuel is 55 cents cheaper a gallon.
-Mike
   / your take on this diesel additive test? #34
-Mike
#2 off road = #2 on road( + color)
   / your take on this diesel additive test? #35
You don't even need b2 . The diesel manufactures recommend a diesel quality of 460 so b1 would be enough although a minimum it is better than what we are running. Someone gave me a few gallons of biodiesel and I mixed it with 1qt per 32 gallon tank of diesel. There was no difference in mileage and I never noticed any difference in any of my additives.
   / your take on this diesel additive test? #36
I looked at the study. Opti-Lube was rated as one of the best additives. I have been using Power Service but thought I would try the Opti-Lube. I looked at Walmart, O'Reillys', and Advance... they did not have it. Who sells the stuff?
   / your take on this diesel additive test? #38
Just got mine Wednesday, came with 2 dispensers also.
I feel ripped though, I didn't get any pen. :eek: ;)
   / your take on this diesel additive test? #39
Another product not listed in that article is made by Texas Refinery Corporation, their "DZL-PEP Artic". It has a HFRR score of about 413, so that puts it right up there just above the number three spot. Treat ratio is 1:1000. Can't have too many sources of good products, eh? (And no, I am not affiliated with them in any way, shape or form).
   / your take on this diesel additive test? #40
I wish they would have tested a sample of diesel straight from the pump since all diesel manufacturers puts additives in the ULSD before they deliver to the station, I would like to see how this compares to the untreated diesel that none of us can get anyway.
6 ROLLS OF CONDUIT (A50854)
6 ROLLS OF CONDUIT...
1995 FORD LT9000 DUMP TRUCK (A51222)
1995 FORD LT9000...
LOT LOCATIONS (A51222)
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
2015 JOHN DEERE 744K-II HIGH LIFT WHEEL LOADER (A51242)
2015 JOHN DEERE...
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A51039)
John Deere 1110...
