Skid Steer adapter plate build w/ boom pole
   / Skid Steer adapter plate build w/ boom pole #1
GuglioLS
Edgewood, NM USA
Jinma 354, 1953 Ford NAA Golden Jubilee, Komatsu Bulldozer
Latest project I'm making is a Skid Steer adapter plate for the FEL QA I mounted on my old Ford. This is the link to that project Sooner or later I'll get a QA setup just like it for the Jinma FEL so I can use all the gizmo's on either tractor. This adapter plate will have a 10' boom pole attached. The main plate and some miscellaneous parts are 3/8" thick that I CNC plasma cut.
You might notice the skid steer plate will be setup similar to a receiver hitch. That was an after thought because I just found that 4" x 3/8" wall square tube laying in a scrap pile. It looked kinda cool so I thought it should be incorporated into this project. The boom pole is 3" od X 3/8" wall square tube so it should work just fine.
Kind of got rained out toward the end of the day, I did get some welding done. I'll need some more plasma cut parts before it's all said and done. Maybe it will be finished by next weekend?
The pole in the above pics has been used on several projects in the past. I used to bolt it to the old trip bucket that was on the Ford, but ever since I removed that old bucket and replaced it with the new skid steer QA bucket, I did not want to drill holes in the new bucket so I figured it would be better to just make a QA setup for the boom pole and make it easy to attach.
These are some old pictures I have using the boom pole bolted inside the old trip bucket, So I know the pole will not bend or break off under heavy load.....
Larry
I made a little more progress on the Skid Steer Adapter plate with Boom Pole. First pic is the finished adapter plate all welded. It's been test fit to the tractor and lucky me it fits like a glove. The next step was to cut a 5/8" wide slot about 10" long through 3/8" thick plate. I did that with a 4-1/2" angle grinder with a metal cut off blade.
After the slot was finished, I welded the boom pole receiver to the plate. While that was cooling off, I wire wheeled off all the rust from the boom pole and primed it, let that dry, then applied the finish coat.
Well it's almost done, I may weld on some backing bars behind the receiver to reduce the chance of the plate bending, then paint the skid steer adapter plate and call it a wrap.
Larry
   / Skid Steer adapter plate build w/ boom pole #3
Looks great Larry, I always enjoy seeing what you come up with.
   / Skid Steer adapter plate build w/ boom pole #4
Larry, did you consider this arrangement to allow you to bring the load back to the FEL. You can reach the boom out and grab something at say 10 ft, and tilt the boom back to the vertical position.
   / Skid Steer adapter plate build w/ boom pole #5
Markham makes a nice boom QA like JJs you might look at. I had them lenghten mine. Surprisingly cheap - I couldn't have built it much cheaper (even if I could build... )
Hey thanks for the comments guys,
I finished it up today, slapped on a coat of flat black, slipped the boom into the receiver, slid in the locking pin and that's that. It won't get that much use but it sure will come in handy when I need it for construction of my metal building. The out of pocket was just right for this sort of thing, total cost was 4 cans of paint, all the plasma cut steel was in trade for a little of my time.
For heavy lifting a cable is attached to the FEL arms and connected to the clevis at the tip of the pole. Thats what I used to do when I had the pole bolted to the inside of the old bucket as seen in the last pics of the first post.
Hey J.J. that's a nice attachment you got there for your machine. Oh hey, did you ever use that metal bending anvil I sent you? I've made a couple of them since then. The first one I made was the prototype and needs an upgrade like yours. I'm finding I need to bend 90's and mine does not have the chamfered edges like yours has.
Larry
   / Skid Steer adapter plate build w/ boom pole #7
Larry
No powder coating this time ? Would've been interesting to see how well that held up on the adapter plate. Is the plasmacam working better for you now?
   / Skid Steer adapter plate build w/ boom pole #8
Nice job!! I am curious to see the cables attached to the top.
Mike
Hi TLB,
Yes proudly no "red neck" powder coating this time! what a PITB that was and not worth it for my tractor implements (IMHO).
The PlasmaCam is working much better ever since replacing the Z axis motor (it was stalling) and figuring out how the software works thank you very much. Drawing complex or oddball shapes are still better using autocad and importing them. For example drawing a true ellipse then stretching it to connect to two X-Y reference points in plasmacam is impossible (for me anyway). I had a guy who wanted a 1/4" plate cut in an elliptical shape 18" wide at the center 84" long at the ends, he was making a futuristic looking coffee table? The biggest challenge was cutting parts over 4 feet as the table is the 4' x 4' model. Learning to rotate the drawing (cut paths) and part to the other side of the table with reference and break points is key to getting "seamless" parts over 4' long. I joined "Plasmaspider" a plasma cutting forum to learn, get ideas and download DXF patterns. I've had the opportunity to cut out some cool looking stuff over the last several weeks, it's been a boat load of fun. Thanks for asking,
Larry
   / Skid Steer adapter plate build w/ boom pole #10
Larry
Hi Larry,
Yes I did, I tried it on some 1/2 in by 3 in wide stock, and it bent it 90 degree.
Thanks
12ft x 20ft Steel Carport (New/Unused) (A59225)
12ft x 20ft Steel...
set of 4 tractor trailer tires Roadforce (A56435)
set of 4 tractor...
1996 Sunflower 1543-38 Folding Disk (A56435)
1996 Sunflower...
2010 Freightliner M2 106 T/A Altec D2050A BR Digger Derrick Truck (A55973)
2010 Freightliner...
METRIC DUAL CUT TAP & DIE SET (A58374)
METRIC DUAL CUT...
14 Gun Fireproof Safe (New/Unused) (A59225)
14 Gun Fireproof...
