Putting in a pool
/ Putting in a pool #1
BigE_
Near Portland, Oregon
New Holland TC33D, LT4000
OK, here's the background:
The wife was out shopping about a month ago, sees one of these above ground pools at Fred Meyers, on sale for $150. 15' wide, comes with a filter, pump, cover, ladder, etc. Sounds like a decent deal, right? Not to mention that the weather is starting to get a bit warm.
So, she brings it home and asks me to set it up. I'm reading online how to set this pool up, and everyone is saying to make sure the ground is level. OK, I live on a hillside -- nothing is level. Not to worry says she - you have a box thingy on your tractor - just level the ground.
Well, the area the wife wanted for the pool was nowhere near an outlet (recall the included pump) and even further away from a water spigot. I walked around the house a few times and finally came up with a place that looked like it might work. It's about 8' feet away from the house, so not too close, and about 20' and 40' away from water and power, respectively.
I hooked up the boxblade, and started scraping away at the ground. I got out the level, and scraped some more. I finally got close to what I thought was level, and checked it out with the level again. At this point I was down 4-5" below grade on the side closest to the house. I still needed to come down another 4" on the house side to get level. This was getting too deep for my liking, especially considering the gutter drain pipes are buried in this area.
So, my next step was to start in on a retaining wall, and bring in some fill dirt. I checked online on Craigslist and found a bunch of places that had free fill dirt, but everyone said bring a shovel. I needed about 50 cu ft.... So, I found a place on my property that had a bit too much dirt, and proceeded with moving it (after clearing and chipping the brush and downed trees on top of it).
Loading up the trailer with the backhoe.
Another loading pic
Getting ready to dump the third load.
Dumping the third load.
I did a total of 6 loads, with each load being a little more than 10 cubic feet. If I do my math right, that's about 7 yards, give or take.
/ Putting in a pool #2
Nice work! Looks like a good weekend project,not too big or too small. However, 60 cubic feet divided by 27 cubic feet/cubic yard is about 2 cubic yards in my book. I think you forgot the third dimension;):D
/ Putting in a pool
Yeah, I was thinking it didn't add up properly. lol. Too tired still, I guess. The hardest part was clearing out the forest where I got the dirt. I had it logged three years ago and it was covered in branches / tops. I probably spent a good 10 hours chipping, cutting, splitting, and stacking.
So, a little over two yards of dirt.... Let me see if my math is still bad:
18' long at 4" height, 15' away is zero height, 18' long. For easier math, make it 16' feet away. So, average is 4" at 8' x 18'. Or 1/3'x8'x18' = 47.5 cu ft. Bringing in 60 cu ft, I should have enough with some to spare, right?
/ Putting in a pool #4
bigE, now I don't feel foolish or alone! After seeing you using a cheapo tractor with little dump cart like I did to move dirt,(I was diggin a trench for my garage addition. MY boys drive the little tractor and I used BH to dig and fill. :D I got the best seat didn't I? :D
I thought using a small tractor and cheapo cart (I had to weld mine back together- it started to come apart at seams) I would be ridiculed.:rolleyes:
Good start on this. Let us know how it works out. Hopefully you got it all hard packed down. I hope you watered it down a little every 4 inch of rise you did unless soil is really damp already. It helps to pack down better with no air pockets so wieght from water in pool won't make surface uneven. (dont make mud but wet it down so it can pack better)
/ Putting in a pool #5
Actually, that is about 2 yards (1 yard^3 = 25 ft^3).
Edit: Ooops -- someone else already said this. I'd delete this post if I could. :eek:
/ Putting in a pool
That little cheap trailer with lawn mower has hauled close to 25 cords of wood. Before I got the bigger tractor, it's all I had to haul with. I'd stack it up high, and it took ~7 loads to get a cord in. I don't know what it's rated for, but green wood is fairly heavy, and I'm sure I exceeded its weight rating quite a few times.
This soil is very much just clay, and I hesitate to put any kind of water on it, because it would just stick to anything it touched. I'm going to level it out with the FEL (back dragging while lifting the front wheels off the ground) to pack it down. Then I'll pick up a yard or so of sand and use that for final leveling for the pool to sit on. That should really help to smooth out the wrinkles in the bottom of the pool.
/ Putting in a pool #7
I don't know if they still do it this way, but years ago they suggested putting down a layer or two of peat moss on top of any fill. It helps protect the liner from stones to twigs poking a hole and makes it nice and soft on the feet.
/ Putting in a pool #8
Big E, fill your loader bucket up with dirt and drive over the fill with your front tires. That will compact it way better than back dragging with the FEL. I like the peat moss idea.
MarkV
/ Putting in a pool #9
*now I don't feel foolish or alone! After seeing you using a cheapo tractor with little dump cart like I did to move dirt,(I was diggin a trench for my garage addition. MY boys drive the little tractor and I used BH to dig and fill. :D I got the best seat didn't I? :D
* Here is my cheapo trailer that don't dump in action.
There are 3 tractors involved in this operation .
/ Putting in a pool #10
We just had a pool installed and I can't over emphasize how important it is to get the area under the pool smooth and rock free. I mean every little bump or rock will want to poke up through your liner. Go around on your hands and knees and pick everything out of your dirt. They also put some foam insuallation under the pool. It came in rolls and is maybe 1/8" thick. This was to help smooth out the area under the pool.
I also had a lawn cart like you have. I found it is quicker just to use the end loader to haul the dirt than the cart.
My pool is a 27' diameter and I had to move about 27 c.y. of dirt to put it in. It is about 4' deep in the ground on one side. I had about 16 hours of seat time.
Good luck with the pool and enjoy!
/ Putting in a pool
LBrown, hey, if it gets the job done and moves the dirt....
Cat Driver - I like the peat moss idea, but I think I like the foam insulation idea even better.
I thought about using the loader to haul the dirt, but there are several problems with that idea not evident from the pictures. Where I was getting the dirt, it was solid and full of roots, and the loader couldn't dig it very well. So, the backhoe was required there just to loosen it up. With not much room to maneuver in the woods, I'd be doing a lot of forward and back just to turn around, and there are a few places I have to raise the bucket all the way up. With the ground so uneven, I really didn't want a full load in the FEL with it 8' off the ground. Also, the little trailer holds a little more than the bucket on the FEL. I'm hauling the dirt about 1/3 of a mile, so fewer trips is better. Finally, I got the wife to run the lawn tractor....
I was driving through town and saw a little 15' pool like the one I'm trying to set up. They just had it out on their front lawn, probably brought it home and had it set up in an hour or less. Hmmm, sometimes having a nice flat surface is a bonus....
/ Putting in a pool #12
I have seen it suggested you put sheets of closed cell foam insulation (Home Depot sheets of insulation) under the pool. Insulates and keeps rocks from poking through.
/ Putting in a pool #13
You just don't want anything under the pool that would crush. The amount of weight will be incrdible.
/ Putting in a pool #14
Fresh water will excert a pressure of ~.43 PSI. As long as the foam can support this pressure (and most any closesd cell foam will), it doesn't matter what the total weight is.
/ Putting in a pool
That's 0.43 PSI per vertical foot. This is a 3 ft deep pool, so the pressure will be about 1.29 PSI. Still probably OK.
Wow, I just calculated out the weight of all that water. 15' diameter. 3.14*(7.5)^2 = 176.6 ft^2. 3' high, so 530 ft^3. At 62.4 lbs/ft^3, that's over 33,000 lbs!
/ Putting in a pool #16
Makes you rethink a 6 foot Tsunami wave or watching Deadliest Catch when the take a 40 footer over the bow...
Also, we have put in a couple of residential sized koi ponds. In those, we used Carpet Padding or old carpet remnants. Insullates and keeps the sticks and stones out.
And yes, I checked, closed cell foam can and is used..
/ Putting in a pool
Area where I took out the dirt. Another 6 months and you'll never even notice it missing.
Starting the retaining wall. My wife is doing this part. Unfortunately, she'll have to take the bricks back up, take out an inch or two of gravel, and move the bricks back to the front of the trench.
The first row of bricks should be below grade, and the front should be up against solid dirt...
RoGator and Terragator Manuals (A63117)
RoGator and...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
2016 Boxer 700HDX Compact Skid Steer (A63109)
2016 Boxer 700HDX...
John Deere Mini Decorative Truck (A61574)
John Deere Mini...
2018 LANDOLL 330 S/A  DROP DECK TRAILER (A59912)
2018 LANDOLL 330...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
