tallyho8
Super Member
- Joined
- Aug 1, 2004
- Messages
- 5,258
- Tractor
- Kubota L4400, Kubota ZD326
I am making a handicap ramp and want to use 2x4s for posts and 1 1/2 pipe for handrail. I would like to round out the top of the 2x4 for the rail to fit into. What is the easiest way to do this?[/QUOTE
2manyrocks has your partial answer. Buy the length of 2x4 that when cut in half and bury or attach, gives you the correct handrail height. You should drill your hole right in the middle of your cut line before the post is cut of course. The only difference is I would suggest an auger bit. Barring that, you could V-notch the rail posts with a hand saw for the rails to nestle into. The rails themselves will hide the notch. Don't forget to angle the corners of the 2x4 toward the rail so you have a continuous hand clasp around the railing without the post interrupting the grip.
1 1/2 pipe = 1 7/8 od use a hole saw
No building code here in Washington County .is 2x4 sufficient to pass building code in your region?![]()
Yes hole saw.
This is the way to go.
Do they make a hole saw that will cut through 4 inches of wood?
Johndeere4300
That looks real neat. I wish I was able to go through the 2" side of the 2x4 instead of the 4" side.
Johndeere4300
Therios Pendragon
That is a very clever mounting system that you have.
I'm waiting for my buddy to get back in touch with me about the router bit and router. He is out of town today.
Before I started on the project, I probably should have asked the question, "Does anyone know of any programs that would have helped pay for a handicap ramp for a disabled low income person?"
I am glad to be able to help out, but it bothers me that a person who worked and paid taxes all their life, and can't afford to pay to get a ramp built, has to depend on the charity of someone else to help them while the govt can subsidize so many other things now.
Sorry, I do not want to make this thread political, but couldn't help myself.![]()
