Tractor Fire Extinguisher Question
/ Tractor Fire Extinguisher Question #1
TruChaos
I'd like to mount an extinguisher on my tractor. Years ago, I had a Halon extinguisher for my Jeep which I used twice. The Halon units worked amazingly well with no powder or residue, but, I'm pretty sure they don't make them any more.
Is there a reasonably priced Halon replacement (no residue) on the market?
/ Tractor Fire Extinguisher Question #3
Halon is great stuff pretty much perfect for computer and electronics rooms and the like. however in the governments wisedom they've forced companies to stop all manufacturing of the product, therefore the only Halon available is whats already been produced.
Supply and demand, plus the added cost of collecting and recycling the Halon means if you want it ya gotta pay:D
So no one has heard of a replacement? It sounds like Halon is going the route of R12. As many of you know, the banning of R12 created a freon black market where Russia and China imported it illegally. Now that demand has dropped, it's not an issue any more.
/ Tractor Fire Extinguisher Question #5
While the no-mess convienience of a halon extinguisher might be attractive.. I think I would opt for a abc chemical style that had plenty of volume.. most of the halon extinguishers i see are pretty darm small.. like for kitchen fires that are confined.
if my tractor catches and diesel, gas or oil starts burning.. I want a good blanket of retardent, and plenty of it... I'd think a minimum of 3a 10 bc.. or so..
soundguy
/ Tractor Fire Extinguisher Question #6
soundguy
Another consideration for fire extinguishers is the local climate and the extinguisher propellent. If one is living where the temps drop to say -30F, then serious consideration must be given to the gas that is used to drive out the retardent or powder. However for general usage in a reasonable climate, an off the shelf normal type ABC unit will certainly do the job.
J.
/ Tractor Fire Extinguisher Question #8
There is a liquid fire extingushing agent called Aqua Blue, similar to halon 1301. It is used primarily in food processing areas and in restaurants.
soundguy
I was given a very small halon extinguisher years ago. I kept it in my Jeep for years and used it to put out three gasoline fires before it was empty. It was one of those 10 inch long units made for 4X4's.
While small, it packed a huge punch. A one or two second shot would put out a pretty big fire if pointed at the base of the flames.
I'll check out the aqua blue units.
Thanks
It appears they still make a Halon like extinguisher in the size and configuration I mentioned in the previous post.
Apparently the 10 inch size extinguisher I used to have, which allowed me to put out three gasoline fires, was a 1 lb extinguisher.
The new extinguishing chemical is called HalGuard (there are others as well Halotron, CleanGuard, etc.) and it's referred to as a "Clean Agent" extinguisher. A 1 lb HalGuard extinguisher is selling for just under $50 at 4x4 parts suppliers. Working in electronics I have seen cases where the powdered fire extinguisher chemical did as much or more damage than the small fire it put out.
Here are the characteristics of HalGuard (H3R).
* No thermal shock to electronics
* No mess or damage to vehicle or surfaces
* Liquefied gas extinguishes hard-to-reach fires
* Does not impair operator's vision
* EPA approved
* United States Coast Guard approved
* Listed and rated by Underwriters Laboratories
* Rechargeable
* Made in U.S.A.
* High quality steel cylinders
* All metal valve construction
* Five year limited warranty
150 GALLON FUEL TANKS WITH BRACKETS (A65643)
150 GALLON FUEL...
2013 Ford Taurus AWD Sedan (A64557)
2013 Ford Taurus...
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A63689)
2012 Ford F-150...
2013 MACK PINNACLE (A65643)
2013 MACK PINNACLE...
ASSORTED STIHL POLE SAW PARTS (A62613)
ASSORTED STIHL...
2018 KAUFMAN 44 FT T/A  CAR CARRIER TRAILER (A59914)
2018 KAUFMAN 44 FT...
