Your towing rigs and trailers
   / Your towing rigs and trailers #451
A 1/2 ton would too only it would ride better, get better gas mileage and cost less. You don't need a heavy duty truck until your over 9-10k lbs with these newer trucks.
I agree 100%. I hear guys on here all the time saying they need a Cummins to pull a John Deere 790 and it has to be put on a 25'GN. Most new 1/2 tons are rated from 11,000# down with most falling in the 9,500# range. My 1/2 ton tows 7,000# just fine.
What you guys need to remember is the new 1/2 tons are twice the truck of the 90's where they had 350 plus cubic inch engines and only 200Hp on a good day. The new trucks have boxed frames, better suspension, and large disc brakes. Works better!
Chris
   / Your towing rigs and trailers #452
Looks like you're hauling close to 7000lbs, A heavy duty truck... 1 or 3/4 ton should work just fine. Yours looks like my rig and trailer setup. I'm using a gas 3/4 ton F250. Wish I had purchased the diesel. Heavy duty pick up trucks have heavy duty brakes and transmission cooling; great for hills.
It feels like 7000lbs sometimes.
tractor 2865
b. hog 525
loader 735
trailer 1600
total 5725lb
My whole rig is rated at 10,150. I weighed in at 10,125. That's is cutting it pretty close. If I stop for a case of beer on the way home, I could be in trouble. I think a new ride is on the shopping list.
I will have to give it to the Nissan. It seems to handle the trailer well with out any drama. It just needs more motor.
   / Your towing rigs and trailers #453
tractor 2865
b. hog 525
loader 735
trailer 1600
total 5725lb
What are you using now?
What Nissan is it?
   / Your towing rigs and trailers #454
From the picture I would say Pathfinder.
   / Your towing rigs and trailers #455
tractor 2865
b. hog 525
loader 735
trailer 1600
total 5725lb
The factory rated weights for these pickups are maximums and you certainly don't want to push your truck to the maximum everytime you're hauling your load. Lots of wear and tear, even at 3/4 max load. From your original blog, you mentioned you had a difficult time with hils. A 1/2 ton will have the power, but depending on the weather and the grades you're climbing, your transmission will need cooling... heavyerduty brakes too. I wore out the brakes in my half ton in no time flat hauling 6,000lbs + - going over the Shasta and Siskiyou passes. If your hauling a short distance, then a 1/2 will probably work. If you're hauling long distances over steep grades, I'd give a 3/4 or 1 ton some serious thought. My typical haul is 1300 mi round trip over steep mountain passes.
With our passion for tractors, later, you'll probably find an excuse to go bigger later and need more hauling capability. Looks like you need more toys anyway, good luck!
   / Your towing rigs and trailers #456
Here is my Bobcat tractor CT440, 2007 Chevy Duramax Truck and 20ft 12k Trailer.
   / Your towing rigs and trailers #458
Awesome setup! Nice truck, trailer and tractor. I would have gone for the ct450, but I would have then had to buy a new trailer and diesel truck. Perhaps I can convince the wife in a few years.
   / Your towing rigs and trailers #459
I wish I had gone with the CT450 also. Thanks for all the compliments:D
   / Your towing rigs and trailers #460
I don't post much, but check in often for inforamtion - thanks guys
Figured I'd add a few
Couple different trucks and trailers - Same tractor
Andy
2016 JOHN DEERE 624K WHEEL LOADER (A51246)
2016 JOHN DEERE...
2012 Terex RL4 S/A Towable Light Tower (A53421)
2012 Terex RL4 S/A...
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A51692)
2013 Mitsubishi...
2015 Ford F-450 9ft Utility Flatbed Truck (A55852)
2015 Ford F-450...
XCMG CV83PD (A53317)
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A53843)
2011 MAGNUM...
