Calling all JD 3x20 owners who use the MMM:
/ Calling all JD 3x20 owners who use the MMM: #1
FRIZ
NW Indiana
John Deere 4720 Cab
The other day I test drove the Kubota B3030 with cab. It was not a satisfying experience. Therefore I am reconsidering the John Deere 3720 cab with 72in mid-mount mower. (I know that the B3030 and JD3720 have not only different price points but also have different weight.)
The task for the John Deere 3720 cab with 72in mid-mount mower would be to mow around the three ponds (1.5 acre, 1+ acre and 0.5 acre). Also I would order a PTO driven leaf blower to get the leaves away from the ponds.
My questions are:
Are you satisfied with your John Deere 3x20 with 72in mid-mount mower?
Would you recommend your John Deere 3x20 with 72in mid-mount mower?
Please help by sharing your experiences.
Thank you,
Regards,
FRIZ
/ Calling all JD 3x20 owners who use the MMM: #2
My questions are:
Thank you,
Regards,
FRIZ
I'm quite happy with my 3720 Cab with 7 Iron 72" mmm which I use primarily for cutting about 6 acres of lawn in summer. In winter, it is used with JD 59 front mount snow blower for clearing about 1/2 mile of driveway and it works very well for that.
My only gripe is that I have to mount a very heavy support bracket for the front hitch when installing the snow blower after removing the mmm and then remove the support bracket when installing the mmm all due to the front mower arms contacting the front hitch bracket. Also, the 72" mmm is very heavy and is a tight fit under the tractor and between the front & rear wheels. I'm told all of the above is resolved with the new drive-over mmm deck.
PS: I'm very interested in any PTO driven leaf blower you find.
/ Calling all JD 3x20 owners who use the MMM: #4
I have the 72" mmm drive over deck and it is quite easy to install.I also made two axles and and 10" wheels to move the mower for storage.This was a huge help because of the weight of deck.I also retro fit my old trac-vac 854 which i had on bx2350.I just needed to buy a new boot for deck and a longer pto shaft for blower.
As mentioned the only pain in the *** is having to take on and off mid pto when changing to the front blower or mmm.Heres a couple pics of the vac
/ Calling all JD 3x20 owners who use the MMM: #6
There has been prior posts of low deck clearance when raised on the 3000 series. Could get hung up on hills, ditches, loading on trailer ect.
/ Calling all JD 3x20 owners who use the MMM: #7
kennyd, many thanks for the info.
My pleasure...there is another brand that my local dealer sells (Finch Services) But I cannot remember what it is or find it with a Google search of the term "pto blowers.
/ Calling all JD 3x20 owners who use the MMM: #8
Yes I would recommend JD 3320 with 7 Iron MMM. Didn't have drive over / auto connect when I ordered - so can't comment. So far the MMM goes on in spring and comes off in fall - on concrete floor - so not really that big a deal. Have approx 2.5 acres. Main use is mowing and snow work with FEL. Didn't really see any difference in cut with BH & FEL removed so they stay on most of the time. Turf Tires seem relatively easy on grass, except maybe sharp turns in 4x4. Area has few hills so mostly use high range for everything. Traction in snow has not been a problem in my application.
Also have riding tractor with deck for close areas and under trees.
Some people say the 3x20's feel tippy. Rear wheels are set wide and fronts set narrow - fronts rub on deck in wide. On exact same spots where uphill wheel of rider comes up the 3320 feels glued to the ground. Only experiencce is on own land so can't comment on how they handle on larger hills.
/ Calling all JD 3x20 owners who use the MMM: #9
Hi:
I have a 3720 cab with a 72"MMM and also I use primarily an 84" RFM. I also have 6" (Each side) Unverferth wheel extensions and run R3's.
The mower cut quality is superb and I'm sure you'd be happy with it. My gripe (I no longer use mine except for leaf collection) is not with the deck itself, but rather the pain it is to take on and off (May be a moot point with the new auto-connect deck).
If you are just mowing you'll be more than happy. If you want to do interspersed 'tractor stuff' you'll be cursing frequently as the deck is too low to realistically do much without taking it off and removing it and putting it on is worlds more difficult than on the 2305 I have.
So much so I gave up on it and now use an 84" RFM exclusively except for leave collection (I use the 72" MMM and a Cyclone rake for that).
So My recommendation would be that if you will be doing anything other than mowing or 'light' tractor duties (no rough terrain) don't do it. Either get a RFM or figure out another mowing solution. For the 3K+ the deck is going to cost you you can get a pretty nice mower if you need to. Your acreage seems like a 3720 is overkill. I mow 5-6 acres with mine and it's overkill for that. (My 2305 was more than enough for that but didn't have the cab. :)
As for stability. I have a tilt meter on mine and once you get used to it you'll be fine. I have extended my wheels a foot so I feel pretty stable on slopes. The only time I've actually tilted it is with the grapple hook on the front carrying unstable loads. I've never had a 'pucker' moment just mowing.
/ Calling all JD 3x20 owners who use the MMM: #10
if your going to look at the 3X20, you could also consider the next larger Kubota as well. The L40's and the B3030 are very different tractors.
2024 MAC TNAR39FR540 40FT T/A  FRAMELESS END DUMP TRAILER (A59906)
2024 MAC...
2016 DRAGON SAND CONVEYOR (A58216)
2016 DRAGON SAND...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2004 JOHN DEERE 160C LC EXCAVATOR (A52709)
2004 JOHN DEERE...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A57192)
2008 INTERNATIONAL...
Iron Bull Trailer (A60462)
Iron Bull Trailer...
