New 2305 - dash lights and other observations
   / New 2305 - dash lights and other observations #13
Sorry L.B. I couldn't resist.
   / New 2305 - dash lights and other observations #14
You can keep LB over here on the JD side if you want!!
   / New 2305 - dash lights and other observations #15
I've noticed between the 2210 and 2305 if the light switch is turned on (headlights or flashers) and you turn off the key lights stay on.
On the 2210 all lights went off.
I liked that setup much better than the 2305 leaving the lights on when key is off
   / New 2305 - dash lights and other observations #16
I agree, I don't much care for the lights being enabled with the key off though one time I was working on the side of the road in front of my house and I left the flashers on because I could. Conversely, if the lights didn't work with the key off, I wouldn't have even thought of it or cared to have them on.
While on the subject of the lights, does anyone know how to alter the lighting switch layout? In other words, when you turn the light switch to the first detent, the hazard flashers come on. The second detent gets you headlights and (optional) worklights. The third detent gets you headlights and hazard flashers.
There is no way to get all three, headlights, flashers, and worklights at the same time. When I snowblow in the road in front of my house, I'd like to have all three going. If I could just add the worklights to the third switch setting, I'd be satisfied.
   / New 2305 - dash lights and other observations #17
I've wished for that too. I wonder if JD did that intentionally because having all the lights on might draw too much current?
   / New 2305 - dash lights and other observations #18
My Kubotas have a separate on off switch for
head lites & tail lights
4 way flashers
turn signals
   / New 2305 - dash lights and other observations #19
I think it's because it is assumed that if the flashers are on then your are on the road-and the worklights should not be used when on the road.
It's very easy to re-wire the worklights onto a new circuit with a separate switch for independent control.
   / New 2305 - dash lights and other observations #20
head li...
Even if the lights didn't work at all on my JD's, I could never swing open my barn door and gaze upon an orange machine. Never happen. Sorry, I can only handle orange on Halloween pumpkins. Just my own opinion.
2021 BOBCAT T870 SKID STEER (A52705)
2021 BOBCAT T870...
Portable Restroom (A54865)
Portable Restroom...
2018 Toro Workman GTX Electric Utility Cart (A55851)
2018 Toro Workman...
2013 Cadillac ATS Sedan (A55758)
2013 Cadillac ATS...
UNUSED RAYTREE RTSG30 TRANSVERSE STUMP GRINDER (A54757)
UNUSED RAYTREE...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
