What carryall dimensions?
   / What carryall dimensions? #1
trook
Gold Member
North Central Mississippi
JD 5075E Cab
Does anyone know the size and thickness of the angle iron king cutter uses for their carryall? For those of you that use the king cutter carryall frame as a base, would you do anything different (thickness of angle, etc) if you were to build one from scratch?
   / What carryall dimensions? #2
The carryall is about an hour away but I am pretty sure it is 2 1/2 inch angle, 1/8" thick. If I was building the frame from scratch I would use cat1 dimensions for the three point hook up -- the top link hole is the wrong size on mine and the bottom pins are not even close to spec in terms of distance apart. I would weld a receiver hitch to the back of it (probably use an HF bumper hitch welded onto a crossbar) and I would run two pieces of angle front and back on the platform piece so I could run the "floorboards" front to back and have them supported at each end. I might make the angle a little thicker if I had some lying about but I have done some terrible things to mine and it is still fine. JMHO
regards
   / What carryall dimensions? #4
I think it is 1/4'' flat stock
   / What carryall dimensions? #5
I just measured My new KK & its all made out of 1/4 inch except for the upper & lower atachment brackets , they are 3/8,s . Heres a few Pics of it on my wifes baby tractor. :D . Bob
   / What carryall dimensions? #7
Cowboy
Does yours have a 3/4 toplink hole and are the bottom links capable of fitting in a 27 1/2" quick hitch? If so mine must be an older model that they have fixed the problems on. -- and thickened up:eek:
   / What carryall dimensions? #8
Cowboy
I,ll go look BRB . OK Yes its 3 inch angle . The holes are 3/4 inch . The width at the lower hookup is 24 inches from center to center of the lower bar brackets . I hope that helps . Bob
   / What carryall dimensions? #9
Thanks Cowboy
Seems like they have changed it quite a bit but it would still not fit a quick hitch very well--- Trook you might want to check cat1 specs if you are making one to line up with a quick hitch.
regards
   / What carryall dimensions? #10
My KK carry all works with Pat's quick hitch just fine.
kj
(INOP) 2005 JCB 506C TELESCOPIC FORKLIFT (A50459)
(INOP) 2005 JCB...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A49461)
1994 Mack CH613...
2011 GENIE GTH-5519 (A50854)
2011 GENIE...
2016 HINO 268 26FT BOX TRUCK (A51222)
2016 HINO 268 26FT...
Pallet Fees (A50774)
