quick xuv question
/ quick xuv question #1
GatorXUV16
Franklin IN
Ok so I just got a new longbed ford and I know the gator will fit on it but I don't know if it will make it over the wheel wells. Will it go over them ok or crush them. has anyone here tried this before.
/ quick xuv question #2
I have had traditional style gators in a Ford F250 bed. I would guess if it makes it between the opening for the tail gate the rest is gravy.
/ quick xuv question #3
I'd be more worried about the precariousness of getting the Gator in/out of the back of the pick up. Get a trailer that's at least big enough for the Gator. It'll be much safer, and not to mention easier.
/ quick xuv question #4
The XUV is about 60 inches wide and I think the space between your wheel wells is 48 or more inches (they still make it wide enough for a sheet of plywood, don't they?) which leaves 12 inches, or 6 inches per side. Not quite enough for the tires to ride up over. I'd suggest creating some wood ramps or "speed bump" to support the inner half of each front tire as it tries to run up over the wheel wells. This will add support and it will make it easier to load. If you get off one way or the other with only half of each tire supported, it'll want to slide the machine off one wheel well and you don't want to bump the sides of your box nor do you want to mess up the Gator.
Also, pay attention to your owner's manual which shows a picture of a Gator loaded on a flatbed truck -- backwards. I believe John Deere recommends loading these machines backwards becahse the engine and transmission weight are rearward biased and you want that weight as far forward as possible.
And remember that a 1600 lb machine with rear weight bias has, say, 1000 lbs on the rear axle. Are you confident your tailgate can support that? Or will you remove that instead? And your ramps are sufficient? And you have tie down points with strong straps?
I'm partial to trailers for hauling equipment, but if you manage to do this and do it safely, post your story here so we can learn from your experiences.
Good luck.
Ok guys thanks a lot for the help. I'll give it a try when I can.
/ quick xuv question #6
I have loaded and unloaded xuv units into the back of full size chevy and ford late model pickups. The chevy being a short box put substantial amount of weight on the tailgate but did fine (gas unit). Later did a well equipped diesel unit in the same vehicle and bent the cable mounts on the tailgate. Current vehicle is late model ford with long box and the unit loads and transports just fine. Put er in 4wd and rear diff lock and just drive over the wheel wells there is not much room to spare and will not work if you have the wrap around style brush guards. You do have to pay close attention when backing out but is not too bad.
2023 John Deere 8R 340 Tractor (A63111)
2023 John Deere 8R...
2022 John Deere 5055E (A62177)
2022 John Deere...
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
Caterpillar T Series Lift Truck Service Manual (A63117)
Caterpillar T...
Kubota Z232 (A60462)
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
