Small leak on 422 front wheel motor
   / Small leak on 422 front wheel motor #51
What do you guys think on rebuilding or replacing with new on those hydraulic wheel motors? I would think that anything over 1/2 of new to rebuild, I would go with new.
   / Small leak on 422 front wheel motor #52
Hi Bob,
Do you know the exact model number of the wheel motors on your 422?
Thanks!
No, I don't. Part of the reason that I have not done anything.
   / Small leak on 422 front wheel motor #53
When I got mine repaired it cost almost $300. They replaced the shaft because of corrosion/pitting around the seal. The new from PT was about $305. I will probably not rebuild it again.
   / Small leak on 422 front wheel motor #54
I have three used 12.5ci White RS motors that I took off mine when I did the wheel motor upgrade to CharLynn 22.7ci. If anyone wants one as a spare or backup, PM or email me with an offer.
That price doesn't sound too terrible for a new one... I will probably give PT a call about them.
Hi Kent, if they are in good condition and you believe they would work on my 422, I might be interested in one. Do you recall how many hours were on them?
   / Small leak on 422 front wheel motor #56
Kent,
Are those motors 1500 psi motors? What is max rpm?
   / Small leak on 422 front wheel motor #57
Not an exact number, but somewhere around 450 hours on them. My 425 is at about 550 now.
   / Small leak on 422 front wheel motor #58
Kent,
They are 12.5ci White RS series, JJ. They're 1500 psi motors, about 140 RPM at 8gpm, as I recall. The complete specs are on White's site. Remember that these have a 1" tapered shaft, due to their use as wheel motors.
Zero Turn Mower (A59231)
Zero Turn Mower...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58214)
2018 LARK UNITED...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52709)
(INOP) 2016...
2018 Ford F-350 Crew Cab Service Truck (A56858)
2018 Ford F-350...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
500BBL WHEELED...
