Small leak on 422 front wheel motor
   / Small leak on 422 front wheel motor #51
What do you guys think on rebuilding or replacing with new on those hydraulic wheel motors? I would think that anything over 1/2 of new to rebuild, I would go with new.
   / Small leak on 422 front wheel motor #52
Hi Bob,
Do you know the exact model number of the wheel motors on your 422?
Thanks!
No, I don't. Part of the reason that I have not done anything.
   / Small leak on 422 front wheel motor #53
When I got mine repaired it cost almost $300. They replaced the shaft because of corrosion/pitting around the seal. The new from PT was about $305. I will probably not rebuild it again.
   / Small leak on 422 front wheel motor #54
I have three used 12.5ci White RS motors that I took off mine when I did the wheel motor upgrade to CharLynn 22.7ci. If anyone wants one as a spare or backup, PM or email me with an offer.
That price doesn't sound too terrible for a new one... I will probably give PT a call about them.
Hi Kent, if they are in good condition and you believe they would work on my 422, I might be interested in one. Do you recall how many hours were on them?
   / Small leak on 422 front wheel motor #56
Kent,
Are those motors 1500 psi motors? What is max rpm?
   / Small leak on 422 front wheel motor #57
Not an exact number, but somewhere around 450 hours on them. My 425 is at about 550 now.
   / Small leak on 422 front wheel motor #58
Kent,
They are 12.5ci White RS series, JJ. They're 1500 psi motors, about 140 RPM at 8gpm, as I recall. The complete specs are on White's site. Remember that these have a 1" tapered shaft, due to their use as wheel motors.
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2014 Ford Fusion Passenger Car, 2.5L Engine - Only 90,875 Miles (A56438)
2014 Ford Fusion...
New Holland 163 4 Basket Tedder (A57454)
New Holland 163 4...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
2018 Ford Fusion SE Hybrid Sedan (A56859)
2018 Ford Fusion...
