MX6 Brush Hog Shakes Tractor?
/ MX6 Brush Hog Shakes Tractor? #1
Bliz
NH-9 Miles from Quebec
I have a JD 6115D tractor with an MX6 brush hog that I loaned to my neighbor to mow a field. When I got the machine back the tractor shakes like crazy when using the mower. I have checked the blades, the stump jumper and the pto connections and I don't see anything unusual or damaged. The gear box on the mower is not making any noises so I assume that is OK. Does anyone have any suggestions on what else to check? Thanks for any info.
/ MX6 Brush Hog Shakes Tractor? #2
The blades and stump jumper are the flywheel for the bush hog. so if a blade cannot run freely it will cause out of balance vib. Mine catches wire and wraps around blade to cause the out of balannce feeling.
Also lower RPM will allow the blades load up with grass and brush then vibrate.
Check if a blade is warped or bent hitting some part of frame.
My MX6 usually vibration free. but gets noisy when above conditions happen.
ken
/ MX6 Brush Hog Shakes Tractor? #3
I purchased a RC 1072 for my 3520 and had to send the first one back as the stump jumper was bent - probably due to fork lift fork damage during handling. The disc was distorted which did not allow the blades to rotate freely - wow did it shake everything!
I also found that after heavy/prolonged mowing the blades would collect junk around the bolts which attach them to the disc. I removed the blades for sharpening and cleared out all the junk form around the bolts and noticed a much smoother operation of the rotary cutter from inside the cab.
Tony
/ MX6 Brush Hog Shakes Tractor? #4
Measure the distance from the blade to the deck, rotate the next blade to the same position and measure again. Much difference and I'd say the stump jumper or the gearbox output shaft is bent.
/ MX6 Brush Hog Shakes Tractor? #5
Bummer. I'm betting the stump jumper or gear box shaft is warped. Good luck.
/ MX6 Brush Hog Shakes Tractor? #6
Make sure the blades are free i had one that was binding on grass and and got stuck almost 180 degrees out of place and my mower was hopping around like a kangaroo!
I had to loosen blade clean out grass and set it back up again.
tom
Thanks for the advise. Yesterday I pulled the shrouds off the pto shaft to check for any damage or bending and that is fine. I did find that when I measured the distance from the stump jumper disk to the top of the mower on opposite sides there is a 1.25" diffference. So I think the advice of a bent stump jumper or shaft is correct. We will be taking it apart to figure out which one. My guess is it is the shaft as the stump jumper appears OK. How big a job is it to change the shaft?
/ MX6 Brush Hog Shakes Tractor? #8
May take most of the day. It would be adviseable to have some help with the heavy stuff. When you are done make sure the slip clutch is adjusted properly too.
Bliz, In the borrowers defense that is a lot of power to turn an MX 6, I think it has a 90
hp gearbox. Hope he is helping out with the repairs.
Steve
jenkinsph, I know the mower is kind of small for that tractor but figured it would be ok as I usually only mow my own field with it. I had a 4720 tractor when I bought the mower and upgraded to the 6115D because I plan to log with it this winter. My saleman stopped by yesterday to take a look at it to see if he could tell what the problem was. I was not home at the time and he loaded it on a trailer and took it back to the shop to be checked out. Thanks again to all for the help.
/ MX6 Brush Hog Shakes Tractor? #10
Most damage to those mowers is not HP related. I have seen them up at the shop with the hole pan sheared off, etc. Hit something going too fast, etc.
D.
Well, it's not good news. I spoke with the dealer yesterday to get a damage figure. He told me the stump jumper is bent, $600.00 and the gear box is badly damaged $900.00 and I need new blades $??.00, plus labor. I only paid $2,200.00 for the mower when I bought the tractor so I told him to not repair it and I would come get it. So much for loaning out equipment.
/ MX6 Brush Hog Shakes Tractor? #12
Sorry to hear this but thanks for letting us know. I am going to be extra careful with mine and not assume to much about its abilities.
Steve
/ MX6 Brush Hog Shakes Tractor? #13
Well, that sucks. The MX-6 is a stout mower - he must have hit something pretty hard.
He broke it, maybe he should buy it... file it on his insurance or something.
D.
/ MX6 Brush Hog Shakes Tractor? #14
I would take the blades and stump jumper to a good machine shop with a hyd. press, they may straighten them for say $100 bucks and I bet the gear box is available for mabey $250 to $350. Brush hog gearboxes are pretty universal within the correct horsepower rating.
/ MX6 Brush Hog Shakes Tractor? #15
I bet the output shaft is hosed. I wonder how much just an output shaft would cost...
D.
Thanks for all the info. Taking the stump jumper to a machine shop is something I will try. When I get it back I will take it apart and see if I can salvage it with just a shaft. I hate to just junk it and I am not in a position to buy another one.
/ MX6 Brush Hog Shakes Tractor? #17
Unless that stump jumper is just completely trashed in the wrong place - I bet you can save it. The gear box might be a different story.
D.
/ MX6 Brush Hog Shakes Tractor? #18
OK, stupid question on my part; but I assume you are using 3/4" impact wrenches to remove the nuts/bolts holding the blades?
What about torquing the fasteners back to spec when you put the blades back on. I don't know of too many people who own a heavy duty torque wrench with a torque multiplier.
/ MX6 Brush Hog Shakes Tractor? #19
agri supply has gear boxes with the stump jumper collar maybe you could get one of them and weld new collar on straight and with new gearbox you would be set
75 HP GEARBOX FOR ROTARY MOWERS - Agri Supply
tom
/ MX6 Brush Hog Shakes Tractor? #20
I had the same question and all I do it hit them with my 3/4" impact. I clean the bolts up good before hand, etc.
D.
JOHN DEERE 7810 TRACTOR (A64278)
JOHN DEERE 7810...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
2006 Dodge Charger Sedan (A64557)
2006 Dodge Charger...
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
Interstate 20ft Tilt-Deck T/A Flatbed Equipment Trailer (A64553)
Interstate 20ft...
2000 Chevrolet Astro Cargo Van (A64194)
2000 Chevrolet...
