BRUSH GRAPPLE
/ BRUSH GRAPPLE #1
BUG322
Hello pretty sure this ? has been asked but scence i dont know hydraulics very well ,i was wondering how to hook a grapple to a 2615 can i just get a 6-way valve or is there an easier more efeective way. thanks for any help
Dan S
/ BRUSH GRAPPLE #2
If your current valve has PB, then just add another single valve somewhere convenient for the grapple. It could even be an electric valve controlled by a toggle switch on the joystick if you have one.
/ BRUSH GRAPPLE
J.J
I REALLY DONT KNOW WHAT A PB STANDS FOR OR IS . I HAVE A 2006 MAHINDRA 2615 WITH FACTORY LOADER IF THIS HELPS ..
THANKS AGAIN FOR YOUR TIME.
DAN.S
/ BRUSH GRAPPLE #4
J.J
DAN.S
PB stands for, power beyond. Some of the MAHINDRA operators might be able to answer that question.
POWER BEYOND (HIGH PRESSURE CARRYOVER): A sleeve attachment which permits the oil flow from one valve (when in neutral) to be used by another valve downstream. Hence, a 3-spool valve could be connected to a 2-spool valve to create a 5-spool valve, The first valve takes priority and thrust have a separate outlet port to return oil from an activator back to the reservoir.
If you can get a 6 spool valve, at a reasonable price, then go for it, but if your current valve is working good, then adding another single valve would work.
/ BRUSH GRAPPLE #5
His loader has power beyond, so it should be a pretty simple install.
/ BRUSH GRAPPLE #6
BUG322,
rback33 says you have PB, so a single valve added to the PB would give grapple control. You can use the manual lever type, or a 12v electric valve. Just activate the toggle switch to operate the grapple. You can connect the grapple with permanent fittings, or if you will be changing out the grapple often, use QD to connect the grapple.
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
Dixie Chopper (A64557)
ACS PORTABLE AIR COMPRESSOR (A64276)
ACS PORTABLE AIR...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A64556)
2016 Chevrolet...
2019 HYDREMA MX14 TIER 4 MOBILE EXCAVATOR (A63276)
2019 HYDREMA MX14...
3098 (A63117)
3098 (A63117)
