taborekle
Gold Member
Hi all,
I have a Kubota B2920 with the Land Pride Easyhitch system and a Land Pride cat 1 blade. I've found that when I am carrying the blade, either with our without the Easyhitch, that I only have about 4 inches of clearance between the bottom of the blade and ground, and that's with full lift on the cat 1. I unintentionally ground out anytime that the front starts to climb a small mound or rise.
Looking at this and my other implements, I can see that it's because the blade hangs down under the lift arm hookup points.
There's no adjustment that I can see that I can make to get more height for the blade. Does anyone else have a similiar problem and a solution?
Thanks in advance,
Larry
Thanks in advance,
Larry
