Hydraulic cylinders leaking
/ Hydraulic cylinders leaking #1
cyberflyrg
Member
Buford GA
Kioti DK45 4x4, Ford 3000
All four cylinders on my Yanmar 2700L front end loader are leaking around the seals. What type of packing/seals are in these cylinders? This is the factory loader that came with the tractor. thanks ron:(
/ Hydraulic cylinders leaking #2
The factory never made a loader. Yanmar had a loader made that they sold in the US under their name for the domestically sold Yanmar models. Are you saying the loader is a 2700L, or the tractor is a YM2700?
/ Hydraulic cylinders leaking #3
hi ron, i will say that if the loader is a Bulldog or V-Tec brand, parts will be a problem from most suppliers.
Do you have the Manufacturer's name or a model number?
What I would do to repair No-Name Cylinders is:
→ remove the cylinders and disassemble them to access the warn out part.
→ bring the removed seal and the cylinder parts to a quality parts house (hydraulic or bearing supplier, even a NAPA will help get the right seals by mic'ing components for the correct replacements)
→ when disassembled you may find o'rings are all that are needed, units need to be taken apart to find out
→ if the leak is not to bad, delay repair, for when the tractor repairs down time won't interfere with needs so much.
YM2700 is a gray market tractor, the loader came from Japan with the tractor. It has all japanese markings and writing on it, so it may not be a yanmar, but it aint a bull dog either.:(
Thanks rhett, thats what I started doing tonight. I removed the cylinders and tomorrow Ill dig into them to find out what is leaking. I have a NAPA store close by and if they cant match them up, Ill go into to Atlanta and find a hydraulic company that can help me with the seals. The rams are nice and shiney with no rust or corrosion and also work great. Very strong loader, just leaks like a basket. I assume they are all dried out from sitting and lack of use. thanks ron
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
1993 CHEVROLET Corvette (A59231)
1993 CHEVROLET...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63688)
2019 Krause...
UNUSED AGT YC-32G SAWMILL (A64281)
UNUSED AGT YC-32G...
2010 FORD F-150 XL CREW CAB TRUCK (A64280)
2010 FORD F-150 XL...
