stihl ms290 wont run
/ stihl ms290 wont run #1
tdenno
I have a stihl ms290 It will start with the choke on but it won't stay running. Any ideas of what I need to do?
:confused:
the air filter is clean-the saw is 3 yrs. old and has worked flawlessly.Earlier today,I cut wood for about 15 min. and it quit.It will start for a second with the choke on then quit when I open the choke.It has new gas,the spark plug is fine and the fuel filter in the fuel tank is clean-I have not screwed with any settings on the carb.very puzzling....
/ stihl ms290 wont run #4
I have the same chainsaw and that happened to me this past winter. Someone told me there is a small rubber hose that runs from the crankcase to the carb that acts as a vacumn to suck fuel into the carb and it can crack. I haven't checked it yet since I have another saw.
/ stihl ms290 wont run #5
Check the tank filter for one. You may have some old gas clogging up the diaphragm. In that case pull the carb off which isn't all that hard to do. If it is a Walbro carb it may be one large screw on the bottom of the carb. Unscrew that and check for microscopic stuff in the needle hole or gummed up gas. When you take the diaphragm off pay attention to which side goes back against the top half of the carb. Not too likely but the carb may be sucking air between the carb and cylinder head boot. That is rare though. Tightening the carb nuts would fix that.
Also as mentioned look for cracked fuel lines from the tank and a return line to the tank...
Been down this road before fixing other folks saws.:cool: The MS290 is a nice little saw.
/ stihl ms290 wont run #6
More than likely the feul line. Have a farmboss that does the same thing every 2 years. The fuel line cracks and lets air in so it doesn't suck enough fuel to keep it running. Last one I replaced I put a good coat of grease on the line. Don't use the saw much now. The biggest fix was to buy a 7900 Dolmar saw. Now I don't have to bother with the Stihl. I need to sell it.
/ stihl ms290 wont run #7
Yea, check the hoses, I had the same problem with my ms290. The best fix I did was sell the Stihl and buy a Husky. No problems ever since.
/ stihl ms290 wont run #8
You basically have an air leak from the impulse hose. It's a common problem on the 029/290 saws. Very easy to change. Your dealer will have it, it's pretty cheap.
/ stihl ms290 wont run #9
I will add one more vote to the fuel line. I have the same saw and had the same issue at the same age...
/ stihl ms290 wont run #10
I had the same problem with a ms250. I replaced the hose in the tank from the filter to the carb and it eended the problerm. Saw was the same age 3 years, I guess thats the life of the $14 hose.
/ stihl ms290 wont run #11
I also agree with checking hoses and carb. More then likely it will be something simple. Own a 250 and 310 great saw, same family as the farm boss 290.
For those said said trade the stihl in for a husky well............ bwahhahahahahahaheeehheehaahaaaaheeehaaa. That's just plain FUNNY !!!!!
could someone explain to me how to replace the fuel line in my stihl ms 290? I found one on ebay-thanks...
/ stihl ms290 wont run #13
Disconnect from carb and use pliers to grab the rubber grommet part of the fuel line where it enters the tank and pull it out. The line should have a fuel filter - now would be a good time to replace ;).
Feed in the new line and use a screw drive to seat the grommet (without poking a new hole) - reconnect to carb - should start on second pull (maybe 3rd)
Worked for me -- others may have better methods.
so I don't have to remove the carb?
/ stihl ms290 wont run #16
My ms 250 would not start this weekend......... come to find out the choke had stuck in the closed position. Couldn't tell untill I removed the air cleaner because the choke control knob would move like it was suppose to.
/ stihl ms290 wont run #17
Others gave good hints, but make sure the fuel mix is new/fresh. Makes a huge difference on 2-strokes.
Oops, re-read original post, using new mix. That leaves fuel filter, fuel line, or impulse hose as likely suspects. Carb diaphragm may also be stiff, may need to "kit" the carb.
RavensRoost
thanks a lot mikefromnh and the rest that helped with my ms 290 prob. It was the fuel line and it's back better than ever....
UNUSED MGY-50KW FUEL HEATER (A62131)
UNUSED MGY-50KW...
40ft Shipping Container (A61166)
40ft Shipping...
New/Unused Quick Attach Flail Mower (A61166)
New/Unused Quick...
2018 John Deere 350G Hydraulic Excavator (A61567)
2018 John Deere...
New/Unused 2in Ratchet Strap (A61166)
New/Unused 2in...
2011 Ford F-350 Service Truck, VIN # 1FDRF3GT8BEA38908 (A61165)
2011 Ford F-350...
