Filter removal
/ Filter removal #1
budlite
Toney, Alabama
NH Workmaster 75
Doing 100-hr service and unsuccessful thus far removing transmission/hydraulic filter. Only supposed to be hand tightened then half-turn with wrench when replaced, but this one put on at factory. Anyone got any ideas on how to get this thing off? Already broke one strap-type wrench. I don't have the correct size ring-type filter wrench and unable to locate one either (its about 5 1/8 inch diameter). Filter is already dented from attempts to remove. Not room to use a breaker bar or very large pipe wrench. Thanks
/ Filter removal #3
I have always used a very large set of channel lock pliers for filter removal........no matter what I am working on the filters are always tight. I would be very careful in ramming a screw driver through it.......if that fails you are SOL.
/ Filter removal #4
Get a better strap wrench, and get it around the filter right at the base, where the filter is strongest. Don't jerk the thing, use steadily applied pressure. Cussing may help.
I'd avoid the screwdriver thing, as well. The screwdriver will just tear the filter open like a can opener. Ask me how I know.
The strap wrench evenly distributes the stress, it's your best bet - better than the plier type wrenches.
That rubber seal has taken a set and hardened, but you should get it, eventually. If you can't find the right combination of cuss words, PM me and I'll try to help.
Good luck.
/ Filter removal #5
I have Snap-on filter pliers that work really well. I don't usually spend the money for Snap-on but these are worth the price. Snap-on Tools
Another option is to use a punch & drive the base disk in the off direction. This is usually what's done after the screwdriver trick doesn't work. MikeD74T
/ Filter removal #6
WalMart has a Fram filter pliers for $9. Long handle, plenty of grip and torque to unscrew a tight filter. It also helps to run the tractor and get the tranny fluid up to temperature before muscling off the filter.
/ Filter removal #7
Good luck.
Excellent advice. Not only do you start off with steady, even pressure on the wrench, but you also start off with steady even language and progress to something more forceful. I have also found that bleeding knuckles and grease, dirt, and sweat in your eyes while your arms go numb from holding them high and in awkward positions seems to help as well. It must help, because I am usually making the sailors blush, bleeding like a stuck pig, and blind when something stuck comes off! I bet my projects would go more quickly if I would just try these things first! :D
/ Filter removal #8
I have a strap wrench that accepts the male end of a 1/2" drive ratchet. You can use 1/2" extensions to get the necessary clearance then use an 18 or 24" 1/2" ratchet to break the filter free. Orient the ratchet so it crosses over the center of the filter, use a few small turns to get the strap nice and tight, recentering after each. I shouldn't say it but I haven't found a filter yet that couldn't be removed using this method.
Dave
/ Filter removal #9
Hah! You funny, funny man!
Been there, done that. Too many times.
It's too bad they don't make an oil filter hammer.
/ Filter removal #10
Do not use a screw driver. My uncle had one stuck on a boat motor, a 350 cheby. He tried the screw driver method and long story short it mangled the filter and he was stuck. Had to have the motor pulled to get it off. If he would have just left the filter on he could have went back and put oil in it and ran it until fall with the old filter then have it fixed when the boat was laid up over the winter.
Chris
/ Filter removal #12
I just did my 200 hour filter change and I think I had to do it the same way as before. When the filter wrench just started bending the filter, I inserted a Sears phillips long screwdriver and pulling on both at the same time It came off.
/ Filter removal #13
Hmmmmm. Some good original thinking.
Two strap wrenches - now why didn't I think of that (slaps forehead).
/ Filter removal #15
I always talk nice to it first, calling it sweetheart etc. You always need to treat it nice before the blue words start coming out.:eek:
kj
/ Filter removal #16
Dave
I had a very tight and difficult to get at filter and this tool worked. The tool was pretty badly mangled in the process but it got the filter off. It was REALLY on tight.
/ Filter removal #17
The filter on my Mitsubish is very well tucked in.
No store strap wrenches fit in, much less the socket driven types.
My technique is to use a length of old seat belt material wrapped around the filter body and I then grip with a pair of vice grip pliars and voila, off comes the filter nice and easy.
/ Filter removal #18
I agree.. I like this better than the screwdriver method because its less messy.. I would try to grab the filter toward the base side so it doesnt crush as much..
Brian
/ Filter removal #19
Their is a cam acting clamp that locks on to the oil filter from the botom. It is all steel, turned with a half inch drive ratchit. I can't remember were I got it, but I had to get it when I was in your situation. It has never failed. Some times I have to use a pice of pipe on the ratchit, it's on so tight, but it comes off.
/ Filter removal #20
Dave
I have one of those strap wrenches like that that accepts the ratched.
It's never failed to remove a filter for me.. though it has on occasion made a pretzle out of a few... sure beats the old trusty screwdriver method though.
soundguy
UNUSED 2026 INDUSTRIAS AMERICA 750 GAL TANK (A62130)
UNUSED 2026...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A62129)
2007 CATERPILLAR...
2025 Swict 66in. Bucket Skid Steer Attachment (A61567)
2025 Swict 66in...
2018 Forest River Cherokee Trailer, VIN # 4X4FCKB26JX130699 (A61166)
2018 Forest River...
UNUSED KUBOTA BRUSH GUARD (A62130)
UNUSED KUBOTA...
2018 INTERNATIONAL LT625 T/A MID ROOF TRUCK TRACTOR (A59909)
2018 INTERNATIONAL...
