yanmar 1610
/ yanmar 1610 #1
schalfback
Member
Can anyone tell me where to get a oil psi sending unit and exactly where is it located.My oil psi gauge does not work.Also has any body added water to the rear tires for extra traction
thank you A happy owner
/ yanmar 1610 #2
The oil pressure switch is located right beside the oil filter. The 1610 did not have an oil pressure gauge though, only a light. If you have a gauge you will need a different sender but the replacement pressure switch for the factory light is here --
Yanmar Tractor Parts: OIL PRESSURE SENDING SWITCH_
Aaron
Hoye Tractor Parts
(940)592-0181
Contact Us
/ yanmar 1610 #3
hi schalfback, yes I added -20* Windshield Washer Fluid to my tires for ballast. the results of ride and traction were immediately noticed by me as an improvement.
→ water - 8.35 pounds per gallon, rim rust over the long term will be an issue
→ windshield washer fluid - helps prevent rim rust and has a lower freeze point than water
→ antifreeze - helps prevent rim rust and the freeze point can be regulated to meet climatic conditions
→ Calcium Chloride - about 11.5 pounds per gallon, highly corrosive, tubes recommended
→ Rim Guard - about 10.8 pounds per gallon, No rim rust, area availability?
the cost of antifreeze or WWF was very close, i chose WWF because it should be more environmental friendly than the antifreeze, at the time of the inevitable tire puncture.
there are many posts detailing the loading of tires for ballast with allot more detail.
APPROX (50) UNUSED 3'x8' CORRUGATED METAL SHEETS (A65055)
APPROX (50) UNUSED...
Yard Mailbox (A64557)
GREAT PLAINS 2400 TURBO CHOPPER (A64278)
GREAT PLAINS 2400...
2009 Caterpillar 345D Hydraulic Excavator (A64553)
2009 Caterpillar...
We Don't Dial 911 Sign (A64557)
We Don't Dial 911...
UNUSED FUTURE HLS82 HYD HORIZONTAL LOG SPLITTER (A65055)
UNUSED FUTURE...
