Stihl Chainsaw
/ Stihl Chainsaw #1
Moeven
I have a STihl 028 AV Super chainsaw that will run for a couple of minutes at full throttle. When I stop using it and let it idle it quits. I have put fresh fuel into it, cleaned the sparkplug, cleaned the air filter. What else should I do? I have taken the spark plug out and cleaned it several times getting a severe carbon buildup. Can anyone suggest to me a particular way to go with this? I have crews needing it up here in Alaska and they ar dependent on it.
/ Stihl Chainsaw #2
The first thing I'd check is the filter inside the fuel tank. It gets gunked up and cut the fuel flow.
It's usually just a carborundum filter on the end of the fuel line inside the gas tank. Change it.
After that, clean the carb really well, or have it cleaned at a Stihl dealer. If you have a plastic carb, not sure if Stihl does that or not, it may be dissolving because of methanol in the fuel.
The other thing that comes to mind is a tiny hole or bad seal on the primer pump. It can suck air into the fuel system and kill the motor. That usually gets really bad really fast though, so you'd likely have noticed it by now.
/ Stihl Chainsaw #4
Who made up the fuel mix? Maybe to much oil, which will cause more carbon build up. Maybe go to a hotter plug. New plug. Set gap correctly. Factory setting on plug is not necessarily correct.
/ Stihl Chainsaw
So in order to get to the fuel filter, I am assuming that I will have to take the entire body off of this unit? Cleaning the Carb should not be too hard from what I can see. The fuel mix is approx. the 50-1 ratio. I have not seen a primer pump on this particular unit.
I am up here in Chignik Lagoon Alaska and have very limited access to supplies for this type of equipment. Thanks for the information.
/ Stihl Chainsaw #6
If it's running properly at full throttle chances are the fuel/spark system is OK.:D
/ Stihl Chainsaw #7
The fuel filter is a weighted affair attached to the end of a soft rubber gas line inside of the tank.
Make a hook from a coat hanger wire and go fishing thru the gas filler opening.
Once pulled out of the tank you can examine/clean or replace it.
Not at all hard to do.
/ Stihl Chainsaw #8
I keep a Husquvarna and I can fix it but I guess the saw you have is a little different. Do you have the owners manual? It may have the carb adjustment procedeure in there, the husky one does.
Anyway I was able to find this, it's a pretty major job and you may not need to do all this depending on how bad the saw has been abused.
Small Engines (Lawn Mowers, etc.): Stihl 028, carburetor body, stihl 028
/ Stihl Chainsaw #9
Found this instruction on idle adjustment (see below), it exactly the same way you tune my saw so I think it may be correct. If you can get it to idle I'd try this first before I start taking anything apart the adjustment screws are easy to find and you should have three.
I found your owners manual and I down loaded it. I have it on my hard drive and can send it.
It's 19mb so it's way to big to attach. You will need to pm me pretty quick and I'll send it to you.
"Make sure the filter is clean, most are washable in water. The L adjustment adjusts low speed, the H the high speed. Screw both fully in and screw them both out 1 1/4 turns. Start the machine and adjust L for the highest idle speed, adjust the idle speed until the chain doesnt turn and the saw sounds right and adjust the H setting until a slight burbling is heard at full tilt and not at the most revvy setting. This allows for a slightly rich mixture that protects the engine from seizure and over revving".
/ Stihl Chainsaw #10
I had a similar problem with my farm boss some time ago. I tried everthing you did and the stihl dealer told me to empty the gas, get some high test and use Stihl gas mix. It worked and I never had a problem again.
/ Stihl Chainsaw #11
Good advice. I ONLY run supreme and the Husky Xp synthetic oil in my saws and never have a fuel related problem. (knock on wood)/
/ Stihl Chainsaw #12
In the manual it will tell you to use high test 89 or higher. Your fuel mix should be 50:1. You may want to check your fuel lines. I know some folks that had issues and they turned out to be cracked or dried out fuel lines. I also agree with the post about the intank filter. You should also take your aircleaner off and air blow that out{this should be done quite often}. I WOULD NOT start adjusting things{carb}. If it ran before but dies now then something happened, chances are it is something simple. Start with the tank filter and tank line, air filter{this does pop in half for easy cleaning}, fuel lines going to the carb etc. Also make sure you have a good plug and the proper gas{important}. Once again I would NOT recommend going to a hotter plug, better to find the real problem instead of creating a new one{burned piston}. Keep us posted on how it is going
/ Stihl Chainsaw #14
You need to rebuild the carb. The needle valve is worn and excess fuel is pooling in the carb causing a flood condition. Carb rebuilds are easy on the 028. Just remove the carb and find the # from it. Your Stihl dealer will have a rebuild kit. Most are less than $10. Might also want to replace fuel lines since you have it apart.
/ Stihl Chainsaw #15
Try turning the carb "L" screw in a bit to lean it up, less than 1/4 turn. If that makes it idle nice but too fast or slow, adjust "T" screw until it is at speed you want and below speed where chain will run (idle speed, screw affect butterfly closed/idle position).
RavensRoost
/ Stihl Chainsaw #17
If you are burning so much oil that the plug is carboned up, you might have excess carbon in the exhaust port. To examine and clean the port, remove the muffler. A clean exhaust port is important to smooth and consistent operation of a 2-cycle engine. Proper airflow is critical and restrictions of the exhaust port or muffler effects the performance. It might not be a problem, but if there is evidence of carbon in the cylinder, it's worth checking along with all the other good advice you've been given.
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
New/Unused Landhonor 26ft x 13ft Metal Carport (A65583)
New/Unused...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
2006 Utility Spread Axle Trailer (A62679)
2006 Utility...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
