New Lighted TiltMeter
/ New Lighted TiltMeter #1
kennyd
Advertiser
Westminster, MD
John Deere 3720 CAB/TLB, JD455
A few weeks ago I received a new Lighted TiltMeter Model #25L to try out courtesy of Rick at R&B Manufacturing, the makers of the original TiltMeter.
Fist first impression of it when I opened the box was very positive. It is very well built and looks like it will last forever. The bubble movement is dampened for a true readout unlike what a regular level would do on a tractor bouncing around. The hardware that attaches the meter to the mounting base is stainless steel, but unfortunately the other hardware included is not. Very high quality 3M tape is also included to attach the base-I am using that for now but will drill holes later if needed. The mounting base articulates enough to provide very flexible mounting in any position, and is very sturdy when the bolts are tightened down. Approximately 12" of wire is included for the light hookup-I did however add the heat shrink to about 8" of it to provide a more finished look where you can see them.
Once installed and wired, I was very impressed by how well lit the unit is-it is very easy to read while lit also. Attached are a few pictures. Thanks agian to Rick:D
/ New Lighted TiltMeter #2
I would mount it with the tape on your hood (the black part) right next to the John Deere logo. Too bad you can't round off the corners to minimize the size of the meter and make it a nice oval centered on the hood.
Just my two cents.
Just my two cents.
I tried it there first, and it just did not look right, plus it blocked the John Deere words.
/ New Lighted TiltMeter #4
Good Evenin Kenny,
I got one last year, and mounted it on my hood with through bolt screws. I leveled the unit out on the garage floor. It has worked great for me, but honestly anything much over 15 degs or slightly approaching 20 degs and my pucker factor kicks in ! :)
Lighted would be nice but honestly, I dont think I would be doing anything at night that would approach those grades ! ;)
Good luck with your new meter !
/ New Lighted TiltMeter #5
That's very nice & would be a great meter to have on a tractor because it lights up:cool:
Think God for no neighbors, Because i do sometimes get out about 5:00am in the morning, or stay out to 12:00am at night when it gets really hot in the summer, and the meter would be handy.
Since i have no neighbors, the only problem i have is the wife coming out asking me if i can quit for the night.....Buts it's nice going out early in the morning before daylight and waking my wife up early :D...(been out this morning, but got rained out)
Kenny,
What did you get your power off of ??........Wire from your headlights ??...:confused:
Thanks for sharing!!!
Kenny,
The dash gauges have lights in them, so I just tapped the wires that feed them-very simple.
/ New Lighted TiltMeter #7
OK Thanks,
I'm going to order one.
/ New Lighted TiltMeter #8
Sounds great Kenny. I have the old one, the 2-way but not lighted. I do a lot of work at night and often flip the cabin light on a sec to see my angle, but lights would be practical for me.
When I got mine a couple years ago, I had to pay the US/Cdn exchange plus the Cdn Customs plus tax(es) and so the unit cost me over a hundred bucks. I have a nice little chrome plated "car-marker-light" that I think I may install on the dash to light it up. I used the real good double sided tape supplied and it still holds very securely so thus far I don't need the bolts or screws.
I work a lot of steep angles,..(some 25 degrees) but I have 6" wheel spacers and loaded tires so pucker factor is reduced to "cautious", "carefull" and "slow" but the meter has paid for itself many times over.
Thanks for your report,
. . tug
/ New Lighted TiltMeter #9
cool idea I will have to get one for the bobcat
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
Case 1083 20ft Corn Head (A61307)
Case 1083 20ft...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
IRanch REV High End Scooter (A60463)
IRanch REV High...
500BBL WHEELED...
