CK25 won't start.
/ CK25 won't start. #1
Harvey7
Annapolis Valley, Nova Scotia
Kioti CK25
Took the ck25 out yesterday, let it warm up for 5 minutes, then started to move some earth, it started to rev up on it's own ( about 3 seconds) then stalled out. It started again and I worked for another ten minutes. It started to rev up again, I knew something was wrong and took it back to the barn. I let it sit for a few minutes, tried to start it but no go.
Let it sit overnight but still wouldn't start.
It goes to the dealer later this week for the 200 hr tune up.
Any idea what the problem may be ?
Tks
Harvey
/ CK25 won't start. #2
It sounds like a failing injection pump. Best not to start it because it can redline and won't turn off with the key. On a gear model you can just stall it, but on an HST you'll have to raise the hood and turn off the fuel or choke out the air intake with a rag. Could be something else, but sure sounds like what happened to mine.
Now I'm having problems with my ignition switch. If not held just right it will turn off.
/ CK25 won't start. #3
First, I disconnected the battery. Then sprayed brake cleaner fluid through the switch, worked the key to the right and left, let air dry. Then sprayed silcone lubricant into the ignition switch. That was about six months ago. So far so good.
Don
/ CK25 won't start. #4
Thanks for the tip, TB. I'll give that a try.
2007 MACK CHN613 6X4 T/A DAY CAB TRUCK TRACTOR (A59909)
2007 MACK CHN613...
2016 P.J. Deck Over Trailer, VIN # 4P5F82028G1250354 (A65563)
2016 P.J. Deck...
2 Rolls of Screen (A62613)
2 Rolls of Screen...
2012 Mack CHU613 Truck, VIN # 1M1AN09Y6CM010558 (A65563)
2012 Mack CHU613...
2012 MACK GU GRANITE 6X4 T/A ROLLOFF TRUCK TRACTOR (A59914)
2012 MACK GU...
2022 EZ-GO ELITE...
