Fan Belts
/ Fan Belts #1
bindian
Super Member
Willis, Texas
Mahindra 6520 4WD
The belt I installed last January when I R&R my hydraulic pump pulley came apart last week. The belt is still making a loop, but the outside seperated from the tooth side. This just with under 100 hours on it. Makes no sense to me.:confused:
hugs, Brandi
/ Fan Belts #2
Brandi,
Here's a troubleshooting guide I found... maybe it will help you diagnose your problem... but I'd suspect that you just got a bad belt.
What brand of belt was it, any way to tell anymore?
  • guide_vbelt_troubleshooting.pdf
/ Fan Belts #3
Brandi, sorry to here about this. :( On the bright side, you have not had all that many problems with the RED BEAST, and the few that you have had have been minor.
Hope that things are getting better for you. ;)
/ Fan Belts
Guys,
The belt is still a complete loop on the outside. All the teeth (in new condition) seperated from the outside loop. It totally seperated, length wise, not cross ways. That isn't in a chart.
hugs, Brandi
/ Fan Belts #5
Yep, that's why I suspect you just got a bad belt. Never seen one fail like that before...
/ Fan Belts #7
Brian,
How is Corporate Aviation these days?
hugs, Brandi
Well, I guess I would say it's not so good... at least not like it was 2-3 years ago... the recession has definitely had an influence.
Did you get the Big Red Beast back up and running? Any theories on your belt failure?
17in. Bucket w/ Teeth Excavator Attachment (A64194)
17in. Bucket w/...
2007 Ford E-250 Cargo Van (A64556)
2007 Ford E-250...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
HORST RSW HEADER CART (A64278)
HORST RSW HEADER...
2022 EZ-GO ELITE...
