Throttle plate screws missing on Kohler engine
/ Throttle plate screws missing on Kohler engine #1
grabbit
John Deere D130
I have a JD STX38 with a Kohler engine. The engine suddenly went full bore and shut it down and found the throttle plate disconnected inside. I do not see the screws. Do I need to pull the engine apart to get them out before firing it up again? Or can I get two new screws and move on?
/ Throttle plate screws missing on Kohler engine #2
I'd pull the head and have a look see.
when putting head back on, how much torc should applied and any particular pattern? Any engine diagrams out there on web?
/ Throttle plate screws missing on Kohler engine #4
What model Kohler, I have numerous service manuals.
Andy
/ Throttle plate screws missing on Kohler engine #6
Those screws can bang around in a cylinder, ask me how I know. It may be a pain, but get them outta there or risk major damage, which would be a real pain. This was a B&S 15 horse riding lawnmower in my case, but the principle's the same. I didn't find out about it until the thing went full bore and made a heck of a racket while I was mowing.
Good luck.
/ Throttle plate screws missing on Kohler engine #7
I agree. Find those screws. They may be pounded into the top of the piston.
When I was a kid my older brother lost a wing nut into the intake of a turbocharged engine. He figured it would "work its way out". It did, after it took out the vanes in the turbo and they in turn took out the engine.
/ Throttle plate screws missing on Kohler engine #8
Look in the muffler first.
Engine model is a Kohler CV13S
Removed plug..did not see anything. Looked up muffler, nothing.
/ Throttle plate screws missing on Kohler engine #10
Look at the point of entry, intake, under intake valve, cyl., in the exhaust valve. If not there, you got lucky.
I ended up dropping it off at a repair shop this morning. Will be 12-14 days before they can look at it. Bought it used 7 years ago and never have had a problem that I could not fix myself. Although, seems like poor engine design to put tiny screws in the carb that can be ingested into engine.
2015 Ford Transit 250 Cargo Van (A61573)
2015 Ford Transit...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
2023 Kubota SVL97-2 Compact Track Loader (A63689)
2023 Kubota...
1997 Chevrolet Kodiak C6500 Aerial Crane (A62613)
1997 Chevrolet...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
12ft S/A Utility Trailer (A61574)
12ft S/A Utility...
