2000 JD 990 4wdr problem
/ 2000 JD 990 4wdr problem #1
wr400
wisconsin
2000 Jd 990
I was pulling a 9ft drag with my 990 in 4 wheel drive an noticed some noise from the front end. Four wheel drive stopped working now. This tracter has 175 hours on it. Never been on pavement an is clean. I dropped the oil in the front end only to find it is clean with no metal shavings. Pulled the drive shaft an no broken coupler. In 4wheel drive the front just chatters now.
How bad can this get? I was pulling on some slick clay when it happened.
/ 2000 JD 990 4wdr problem #3
When you pulled the driveshaft to the front axle, did you have the front end jacked up? If so, I assume you tried turning the input shaft by hand. If you tried that, what happened? Both tires rotate? Just one tire rotate? Neither tire rotate?
/ 2000 JD 990 4wdr problem #4
The problem might not be in the "pumpkin" or differential. You might have a broken axle or a problem with the planetary gears in the wheel assembly.
Good suggestion from kebo - jack it up and with the axles supported - spin the driveline and each wheel. Both with 4x4 engaged and not. Listen and feel for grinding, clunking, etc... that can help to isolate where things have gone wrong.
Keep us in the loop.. good luck.
AKfish
with the front jacked up both wheels turn! No noise but they do turn oppisit of each other.
Jeff
/ 2000 JD 990 4wdr problem #6
Jeff
So it would seem that the front axles and differential are ok. The two tires will rotate in opposite directions due to the open differential.
I would jack up all four tires, put it in 4x4 and in low gear. Crank it up, ease the clutch out, and see what happens and if you still hear the same sound. IF the front wheels don't turn then, something maybe damaged or broken in the transmission where the front driveshaft gets its power from. IF all that works, then see if you can listen where the sound is/was coming from.
Jacked the tractor up No strange noise coming from any where! Went to dump the front diff oil an it was under pressure! How or why? Came out nice an clean but what is causing pressure an could that have been the problem. I looked all over for a vent but couldnt seem to find one. Any ideas?
Jeff
Jeff
No body has any Idea to why the front end is building up pressure? Or if there should be a vent to relese it?
/ 2000 JD 990 4wdr problem #9
That's a good question. Do you have the service manual? If the manual doesn't answer you could try contacting Deere via their main site. Some questions haven't been asked yet here.
I had a 770, yes it's smaller but it's very similar. I don't remember any vent on the front pumkin..but that doesn't mean there wasn't. :)
Ok here is a update! Finally got to dig into it. the plate the holds the axel in the tractor was loose cant see it couldnt tell the bolts were loose but sure enough they were an that is what was causing the problem with the MFWD.
Guess the axel would pull a bit an cause the drive shaft to slip.
Any way all is good.
/ 2000 JD 990 4wdr problem #11
Hey, I have the exact same problem with my 2005 990. I am happy to hear it wasn't a huge issue for you you. Could you be more about what you had to fix? Thanks
/ 2000 JD 990 4wdr problem #12
Castles has not posted since 2010. I would suggest that you send him a ''Private Message''. Good luck!
/ 2000 JD 990 4wdr problem #13
I have a 2001 John Deere 990 tractor That I bought new with 411 hours on it.
recently having a noise while in four wheel drive.
Took the driveshaft out, which is a easy job.
Some ball bearings fell out when removing shaft and cover.
Upon looking at drive shaft, one end was good, with almost no grease,
The other end was missing parts, balls, bearings,ect,
looking at the drive shaft it self, No lubrication, grease,ect.
The grooves where the balls ride was severely wore and balls had fell out, this is the end on the rear end, 6 balls,1 missing. Splines on both ends at tractor are good, no ware.
I will need a new drive shaft, about $400 and some balls, new spacers, 1 plastic piece called seal(?) ect
Cost about $500.
This is a place to regrease every year or two, or even couple of hundred hours.
No mention of maintained in the service schedule?
Do yourself a favor and grease this some at least!!!
ALSO: I have a stump cutter from woodlandmills.ca ,that I used to cut stumps,
75-100 so far
Hope this helps
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
Pallet of Anchor Shackles (A61166)
Pallet of Anchor...
Deere 333E (A60462)
Deere 333E (A60462)
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
2015 Vermeer SC30TX Tracked Walk-Behind Stump Grinder (A61567)
2015 Vermeer...
2023 CATERPILLAR 926M WHEEL LOADER (A62129)
2023 CATERPILLAR...
