What type tire
/ What type tire #1
airmedic31
Martin, Tn.
Kubota 5030 HSTC with FEL
Ok folks. Decided on the M7040HDC FEL. I can get either the standard Ag tires or the R 4's for the same money. Most of my work will be in pasture / grass with a good deal of loader work moving pallets around #2000lb from trailer to tralier. Will be working hay , occasionally some finish mowing large lots. What tire should I choose to best suit my overall needs???
/ What type tire #2
I went with the R4's anticipating cutting my lawn later with the tractor. Now I wish I would have went with the Ag tires. The R4's don't pull well in mud. I'll probably get a ZTR sooner or later to cut the yard. Currently using a two riding mowers anyway.
They do pull well on dry ground though!
/ What type tire #3
Your overall use indicates R4 tires. They are easier on the landscape and good for loader work. When I prowl my pasture, I like the fact that I'm not leaving a trail.
/ What type tire #5
Here we go again.....
Just get the big black rubber ones.
If they don't work out for you get ones with a different tread, on a different set of rims, swap 'em around from time to time (say at 10 am and 3 pm) see what works best for YOU.
Get all 3 sets, get 3 different tractors so you won't have to swap 'em around.
Option B: Read all the other threads on this topic; hint/clue there is a Search link at the top of the page.
/ What type tire #6
Good post REG ; but where'd you come up with the 3 tractor idea?
/ What type tire #7
I vote for the ags, had them on the bx23 and wished i had industrial tires, then bought a bx24 with the industrial tires now i am wishing for ags.. i cant win
/ What type tire #12
I have a B7800 with ag tires and the rears are loaded. I finish mow about 5 acres with it around my house, and brush hog, use the loader, etc, etc. The ag tires don't tear up my lawn, and they sure come in handy when I'm down in the hollow. I suppose I could tear up some yard dirt if I tried, but I really like the ags. Best of luck,
Pat
/ What type tire #14
R4s are great for loader work but in your aplication, R1s would work great. What type of soil are you working on? R4s are wider and help stabilize on steep hills while R1s are narrow and have more grip on soft soil and muddy conditions. Ive heard that R1s wear quicker that R4s on pavement but they are both nice tires. I personally like the R1s and wish my lawn tractor had them. :D
UNUSED WOLVERINE HYD 6 WAY DOZER BLADE (A64281)
UNUSED WOLVERINE...
2015 Ford C-Max Hatchback (A61574)
2015 Ford C-Max...
2015 Ford Fusion AWD Sedan (A61574)
2015 Ford Fusion...
CRATE OF UNUSED KUBOTA PARTS & BRACKETS (A64280)
CRATE OF UNUSED...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
1998 Mack DM690SX Chassis Truck  (A62679)
1998 Mack DM690SX...
