New TYM T293
/ New TYM T293 #1
Mike5252
Cleveland, Ohio
JD 2320
I was just browsing around the internet this afternoon and stumbled on a new TYM model (new to me at least). A T293. Basically a T233/273 except a 29 hp engine, slightly different front grill, and information said it ran smoother.
Has anyone seen one of these? Looked pretty slick.
/ New TYM T293 #2
I saw that too. Also larger tires and so a wider stance and higher ground clearance. I think the extra 2 HP may come from the extra 100 RPM, although that wouldnt explain the increase in PTO HP.
Seems like an improvement on the 273. Hmmm, wonder if when my tires are sufficiently worn, my 273 can be transmogrified into a 293?
/ New TYM T293 #3
I saw the info posted on the TYM Website also, and I do believe that the only major difference between the 273 and 293 is the larger tire size. I took possession of my '09 - 273 in April and I'm totally satisified with it. However, I cannot see any HP difference. The 273 and 293 have the same motor - where is that extra power (2hp) supposed to come from? I certainly don't see it. They list the exact same motor spec's for each model. I agree with Bob, if I buy larger wheels/tires can I redesignate my machine as an 293? I don't think so, but it might be real nice to have the additional clearance/stance that those tires would give. I just don't see how TYM can list it as what it apparently is not -- a larger HP'd machine. Just my .02..... nevertheless...TYM, if you're monitoring this -- I do "truly" love my 273.
Gregster613
/ New TYM T293 #4
Gregster613, I lived just below you in Poway for many years. Used to spend lots of time in Ramona, go to Dudleys on my way to Julian and we went to watch my brother race motocross at Barona. It was a good place to live. I do miss it once in a while but then I remember traffic on 15 and 163 going down town and I get my head back on straight.
Maka
/ New TYM T293 #5
Gregster613
Exactly what I posted a month ago or so. . . must be just be the hp at a different engine RPM. Kinda lousy advert if you ask me. I too love my 273 (TYM, if you're listenting), but tires aside, why re-market as a 29hp? In fact, if I'm not mistaken this same mitsubishi engine is rated at 26hp for the Mahindra 2615 series. Again - its all dependent upon what RPM engine is turning at. . . Almost seems as if they're admitting that the 233 is underhorsepowered for the job. . . .
Great tractors, incredible warrenty - don't dick around with a product that sells itself - just give folks 5min on-board and they'll see the difference.
Regards,
Pete
/ New TYM T293 #6
I have the Montana T2734( made by TYM) I didn't like the way it was always spinning in the mud so I changed the tires to R1's. Gave me a bigger tire both front and rear, and its like night and day the way it goes in mud now. Getting those R4 tires off was the best thing I ever did, wish I had done it the day I brought the tractor home.
These are the tires I put on.
Titan® Tire catalog
Titan® Tire catalog
/ New TYM T293 #7
Maka, Glad to hear from you. I read many, many of your posts while I was determining which flavor of tractor to seriously look at. We "used" to have a Mahrindra dealer in town, still have a Montana dealer and I looked at both of them seriously...I believe that the quality was equaled out between those and the TYM; but I just couldn't manage to beat the end-all price & warranty for tractor and equipment that I wanted. Plus, the basic tractor weight difference was substantial. Anyhow, I wanted to tell you I've lived here since retireing from the USMC at Camp Pendleton in 1999 and the town has grown, traffic is substantially heavier now - Hwy 67 has become a potential death trap and Hwy 78 is not much better. So I hear and understand your comment about getting your head back straight. I used to commute daily between here and Pendleton for 2 years before I retired from the military. Thankfully, I don't have to travel either of those roads on a daily basis (I'm lucky enough to work right in town at the High School) and because of that I love living here as much as I love my new 'Little' tractor. I sure do appreciate reading and absorbing all the information you choose to share whenever anyone has a problem or asks a question and you respond. Thanks from North County...Gregster613
/ New TYM T293 #8
Good to hear from you. I used to go up the back way out of Poway and head hwy 67 to Santee and Lakeside. It was dangerous back then and I left in 2002.
As I recall, the Mahindra dealer was on the right side as you just enter town. They also were a trailer dealer, right? Well, enjoy your tractor. Is is a great little machine.
Maka
/ New TYM T293 #9
The specs for the 293 show max rpm as 2800 as opposed to the 273 at 2700. That would do it. I would like to know what they changed to get that - just changing the gov or what.
/ New TYM T293 #10
Yes, the extra 100 rpm at HP measurement might do it, but it wouldn't explain the increased HP at the PTO which is the SAME RPM as the 273. It's not a turbo, so they aren't just dialing up the boost -- so,...what? It's not just an academic question; I have a 273 - which I love dearly (400 hrs and counting). In low gear it has no trouble spinning all 4 tires on dry dirt or packed gravel. It should easily handle larger tires and more HP could only help. Oh, yeah, hydraulic flow appears slightly
higher also. Can that be a result of the extra 100 RPM? Maybe, but I don"t run at that RPM..
Higher ground clearance and a wider stance would be good in my case - 120 year old forest with uneven ground - trail making, minor logging, way more dirt digging and moving than I ever expected...(only because now I CAN, you see).
So can TYM or a dealer or anyone more Knowledgable than me (that doesn't take much) respond with a definative answer?
/ New TYM T293 #11
I'm not a dealer, but I have a background in engines so I'll take a stab.
With diesels or gassers, that have a fixed compression ratio and fixed displacement, power is proportional to airflow. Increasing the rpm will increase the power until the airflow ceases to increase due to increased pressure losses in the induction system and windage losses in the reciprocating components. That's why you see the HP vs rpm curves go flat or even hook over at high rpm. Gassers actually throttle the air flow to control power until thay are at wide open throttle. Diesels do not have a throttle plate. The air induction system is wide open ( except for the airfilter).
With diesels, HP is also proportional to air flow AND fuel to air ratio. So you can "turn up the wick" to get more HP at the same rpm in a diesel. However, the engine and driveline components must be able to withstand the increased power and torque and the engine components have to be capable of withstanding the increased gas pressures and temperatures that go along with the power increases. So my guess is that the increases in power that you are talking about are due to turning up the pump to allow more fuel at a given rpm. In effect, the HP vs rpm curve is incrementally adjusted upward by increasing the max fuel limit in the control.
Hope this helps you understand the power increase.
/ New TYM T293 #12
Thanks, Jerry. I didn't know that about the fuel mixture.
So, I guess the path would be - when my tires are worn out - to get larger tires and wheels, and then if there is a slight lack of power, to crank up the fuel flow a bit.
/ New TYM T293 #13
The caveat is you have to stay within the power and torque limits of the driveline design and the pressure and temperature limits of the engine design or you'll find the weak spots in the tractor.
I see you live in Kingston. I spent my "other life" in the Seattle area - 37 years, 34+ working for the Lazy B as a propulsion engineer. I sure don't miss the traffic!
/ New TYM T293 #14
Yes, well I would hope that TYM has properly calculated that a slight tweak is within the abilities of the engine. If not, I would expect to see multiple posts here from new 293 owners about blown engines long before I wear my tires out and make the change. I suppose one problem would be how to goose it exactly 2 HP without a dyno...
Yes, Kingston is on the other side of Puget sound from Seattle. I haven't gone there in years. Western Montana is also a wonderful place to live, but we both have to figure out what the heck to do about winter.
/ New TYM T293 #15
They obviously conferred with Mitsu about the engines abilities. Crank up the RPM the pump spins faster, hence the pump pumping more.
Simple really.....
2hp isn't going to bend a 2inch thick frame either. The new loader is only a minor tweak up from the 273's also. Same hoe. I kinda like the grill on the 293 more also. Looks meaner...
These things are built to take a measly two more hp which you never use anyway. When is the last time you worked your machine at 2700rpm? I like the larger wheels too. I think they just upped the ante because the new bobcat upped it for them. I wish the bobcat had been a choice when I got mine, I like it. Probably would have stayed -RED- but choice is good.
Lets not get jealous guys our little 273 can do whatever this one can, just not as mean looking.:p
/ New TYM T293 #16
Perhaps the HP difference is a consequence of changes in emission requirements that caused manufacturers to adjust the fuel/air mixture. This is what happened with the Kioti CK20. It went from 20 HP to 22 HP.
The bigger tires are just so it looks as big as its competitors in the same hp/weight classes, IMO. Of course, I like the bigger tires and 2 HP is almost 8% more, when and if you need it. Nice "improvements" to this tractor.
/ New TYM T293 #17
Nope, RPM's were raised 1000. Usually when they change emission requirements we lose HP. 2 more hp is on the top of the RPM band so its really not worth much. Not like they got 2 more hp throughout the rpm range. It's just PEAK hp.
Same engine. Mahindra uses it too, but theirs is another 2hp less than ours. Because its 1000 RPM less. 2600rpm redline iirc. it's just a numbers game.
I'm also quite sure the 2800redline is MAX. for this little tiger.;)
/ New TYM T293 #18
Simple really.....
How do you explain the statement that the PTO horsepower went up also? Unless they changed the gears, that occurs at the same engine rpm?
/ New TYM T293 #19
I'm sorry if I seem to be nitpicking, but my intention is to eventually replace my tires with the larger 293s'. If I don't fully understand all the differences
I could make a big mistake. For example, an earlier post here (thanks, Tom59) prompted me to look at loaders. Using the Tym site's compare function, I can see no difference in the loader specs for the two tracters. Yet they are different model names. So now I'm wondering if TYM used the same loader but had to slightly modify it to accomodate the higher stance. I worry that with my 273 on bigger tires I might not be able to reach down as far to dig or use my grapple in the same way.
As for the horsepower issue, It would seem that about 1 of the extra HP can be accounted for by the extra 100 rpm and this wouldn't be useful in practice, but the rest of the gain came through tweaking the air/fuel mixture and would result in increased HP (and torque) throughout the RPM band.
Anybody see any other changes>
y
/ New TYM T293 #20
Not sure I understand the question. What rpm is it measured at? They don't elaborate. These are peak numbers, no?
t273:
Engine HP(kw)-Gross 27(19.8)
PTO HP(kw) 20.7(15.4)
Rated engine speed 2700
t293:
Engine HP(kw)-Gross 29(21.3)
PTO HP(kw) 21.8(16.4)
Rated engine speed 2800
2012 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A66736)
2012 Freightliner...
GENIE GTH-842 TELESCOPIC FORKLIFT (A65056)
GENIE GTH-842...
2006 JOHN DEERE 310G BACKHOE (A65053)
2006 JOHN DEERE...
2018 Rotary SM18N001 18,000lb. Hydraulic 4-Post Auto Lift (A66736)
2018 Rotary...
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
2018 Chevrolet Suburban 4x4 SUV (A66738)
2018 Chevrolet...
