Sickle Bar Dearborn 14-15 sickle bar mower ??
   / Dearborn 14-15 sickle bar mower ?? #1
rut3556
Amherst, NH, USA
Kubota L2250, Kubota TG1860
Howdy,
I realize the Dearborn 14-15 sickle bar mower was designed for use with the Ford 8/9N series tractors, but would it also be usable on a tractor with a standard 3 pt. hitch? I have a chance to pick one up cheap, but if it won't work for me there isn't much sense in it. :)
Thanks much,
RUT
   / Dearborn 14-15 sickle bar mower ?? #2
Howdy,
Thanks much,
RUT
As far as I know, Ford 8N and 9N have the standard (Ferguson) 3pt hitch. Check the N Tractor Club for info on that mower.
N Tractor Club
Here's the operating manual
Dearborn 14-15/16 Rear Mower - Owner's Manual
Good luck.
BTW:I have three sicklebar mowers: an Allis Chalmers 80T tow-behind mower (7-ft cut), a Massey Ferguson 41 3pt sicklebar mower (7-ft cut) and a mid-mount sicklebar mower for my 1951 Farmall Super A (7-ft cut).
Expect to replace the sickle sections and probably the guard/ledger plate assemblies to get the mower to cut properly (up to $200 for parts if all the guards need to be replaced).
Flusher,
Thanks much for the info. In researching this, it's apparent this particuilar mower is really set up for the 8N type tractors. Probably what I really need is a tow behind such as you have.
Thanks again,
RUT
   / Dearborn 14-15 sickle bar mower ?? #4
Just acquired a Dearborn 14-15 with 6 ft. bar. it looks like it's been used recently by the grease and the grease fittings but I think it's going to require major repairs to the cutter bar. Where would be the best place to acquire parts? Will be trying to adapt this for use on either a Kioti HST35 or an International 444. Maybe just better to scrap it or put it on the market for sale. Any help would be appreciated. County Sawyer.
2018 Ford F-450 Ext. Cab 4x4 Mason Dump Truck (A53422)
2018 Ford F-450...
Komatsu WA180-1 Wheel Loader (A47477)
Komatsu WA180-1...
2012 Infiniti QX56 SUV (A55853)
2012 Infiniti QX56...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
Harrell 3605 (A50123)
