gasoline leak
/ gasoline leak #1
CadizHunter
MF 165 - glass filter directly under tank on port side- looks like gas leaking out of pit-cock toggle on top of glass assembly (there is a 7/16 nut between pitcock and glass....tightened alittle, but didn't slow leak). Leaks when open or closed.
I don't think I have a oring above glass....unless it's stuck up there....I don't think thats where it's leaking.
Problem #2- Carb on starboard side always wet with gas. no drips. NOT coming from problem #1
(BTW- I need to screw with my choke lever sometimes hot or cold. Not sure if this is related or relavent)
SAVE MY MPG!!!
/ gasoline leak #2
SAVE MY MPG!!!
You need to get that to a dealer immediately if it's a MF 165 Diesel tractor leaking gas.
Tractor Repair: MF 165 diesel, perkins diesel engine, massey ferguson
/ gasoline leak
I didn't say diesel.....I wouldn't have a carb or choke! LOL
..........just a leaky petcock shut-off :(
/ gasoline leak #4
Not a MF guy.. but those fuel valves are SUPER easy to repalce and usually under 50 $.. many times it's just packing or an oring in the valv ethat needs replacing.
as for prob 2 not being related to prob 1, I think you are off base. if the valve leaks externally..it likely leaks internally too.. meaning the carb could be overfilling if it also has a bad flaot valve.
you need to get this fixed before you hydrolock that engine when you dump your load of gas into the crankcase.
soundguy
/ gasoline leak #5
Is this the kind of sediment bowl with a bail under it with a threaded knob to tighten the bowl up to the housing/shutoff? If so, you certainly have a gasket, maybe not an O-ring, where the glass mates to the housing. That's a very common leak site. Maybe a mirror and good light will show you something.
Jim
UNUSED JCT 2 PRONG BALE SPEAR (A62131)
UNUSED JCT 2 PRONG...
New/Unused 1in ALR Impact Wrench (A61166)
New/Unused 1in ALR...
1996 Great Dane 50' x 102" Reefer Trailer (A62613)
1996 Great Dane...
UNUSED JCT QUICK ATTACH 60" PALLET FORKS (A62131)
UNUSED JCT QUICK...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
2012 Toyota Camry Sedan (A61569)
2012 Toyota Camry...
