What can I get for my "04" 1533 w/FEL?
/ What can I get for my "04" 1533 w/FEL? #1
MrSteve
Middleport, NY
John Deere 2025R
What can I get for my "05" 1533 w/FEL?
Hi all... I was thinking about selling my 1533 with a 1525 FEL. It has 375 hrs on it and has been well kept by me and still looks really good to excellent, heck I even wax the thing.
*2005, 1533 with 8x8 trans
375hrs
R-4 tires
Tractor mounted joy stick is the only option
1525 FEL with std mounted bucket, I think it is a 60" bucket? It just passes the front wheel width, still looks new, it goes without saying, dirty at the pivot pins grease points.
What work has been done...
All needed oil and filter changes (engine, trans, air, fuel and so on)
Engine cut off solenoid
Right side hub to axle seal
(all work done by me)
I would rate the tractor in excellent condition, body, engine, trans, tires, FEL.
(see older photos in my profile link below, the tractor pretty much looks the same to date)
Reason for sale... Plan on moving out of state and just don't want to move it all.
I live in Florida (for pricing thoughts) and it has always been kept under cover.
I also have "stuff" I would like to sell with it. If you can give some thoughts on maybe a package price (break it down) or should I just sell the below stuff on its own?.
72" Kodiak brush cutter (ok now the cutter doesn't look so good, but works perfectly)
48" box blade (used maybe 6x)
3pt post hole digger with 9" tip (off hand not sure of the maker) used maybe for 30 holes
3pt spreader, can't remember the "for sure" size, but I think I have 200lbs of grass seed in, used maybe 3x.
5x8? chain harrow, 90%+ of the black paint is still on it
Thanks for any insight.
EDIT... Sorry, it is a 2005, I changed that info in my post and title.
Anyone?
Maybe you can point me to a web site or sites where I can figure out the price on my own?
/ What can I get for my "04" 1533 w/FEL? #3
Hi,
Tractorhouse will give you an idea of worth.
Also try Machinefinder, machinelocator, ironsearch.
Hope this helps
Good luck
Thank you... I am going to give $15,200 a shot and see what happens.
Anyone else have any input?
In the mean time, I got some hits on the 15,200, but having hearing the voices of some that I talked to and watching drive ups, I knocked it down to 14,500. With the new price I have noticed driver ups taking a look and writing down info, before the drop not to many took more then a 1 minute looking then would just go on their way.
Well looks like it is gone, I'll post what I let it go for just in case it is helpful to someone else...
Tractor, Loader and 72" bush mower (Kodiak)... $13,000.00 (other info can be found in my 1st post above).
/ What can I get for my "04" 1533 w/FEL? #7
So will there be another MF in your future?
Good luck with the move.
I hope so, but not any time soon... It matters if and when we make the move, I just hope we go somewhere so I do need another one.
/ What can I get for my "04" 1533 w/FEL? #9
If you are going to need a tractor after you move, you should take this one with you!! There probably aren't a dozen on the planet that are in this good of a shape.
Good point, but it would have been such a pain to move out of state with so much "big" stuff. Who knows, maybe I'll get lucky and need something "much" bigger, lucky in more ways then one.
2015 FORD F-250 SUPER DUTY (A60736)
2015 FORD F-250...
2013 GMC Sierra Service Truck, VIN # 1GD422C84DF134632 (A61165)
2013 GMC Sierra...
KBH Tank Trailer (A61307)
KBH Tank Trailer...
Giyi GY-STB47 QA Telescopic Boom (A60463)
Giyi GY-STB47 QA...
10' Container w/ Side Door (A60463)
10' Container w/...
2018 TROXELL 130BBL VAC TRAILER (A60736)
2018 TROXELL...
