HST gear range L-M-H select issue
/ HST gear range L-M-H select issue #1
StrangeRanger
Gold Member
Northern VT
L3400 HST
I've got an L3400 HST and from day one the switch between L-M-H has been a less than pleasant task. At first I thought maybe it had to "break in" or would change w/ use. But it's still a PITA to do.
Per the manual's suggestions I've tried leaving "between" gears and pushing the HST pedal a tad. I let it sit for a bit after coming out of one selection and going into another and lots of other things, but it's still 9/10 times a chore.
Anyone else experience this? Got any tips for faster/smoother gear changes? Does it matter that I'm in 4WD 98% of the time?
Thanks,
j
/ HST gear range L-M-H select issue #2
My L3400 is the same way. The gears are tooth to tooth when this happens so you have to move one gear of the other. Hitting the go pedal moves one, rolling the tractor moves the other.
What I do when it gets ornery is push on the gear selector while at the same time very gently pressing the go pedal.
There is nothing wrong with your tractor, it is just the nature of the beast.
/ HST gear range L-M-H select issue #3
I have a B2710 and sometimes it gives me the same problem. Seems to me it hits a lot when it happens and reading the question on 4 wheel drive is making me think it is worse when in 4 wheel drive.
/ HST gear range L-M-H select issue #4
I have an L3400 and B7800 of which both, on occasion, do the same thing. Simply move forward a little, stop, and shift. Repeat if necessary. be patient and don t force it.
/ HST gear range L-M-H select issue #5
That is how it works on my GL3240 to. I don't think the gears are synchronized like in a car transmission so the movement helps the gears align.
/ HST gear range L-M-H select issue #6
I just put the FEL down and add a little down pressure most of the time, it works quite well, I find it works easier than any other method I have tried.
/ HST gear range L-M-H select issue #7
Same on my L3400 HST. I just give a tap on the hydrostat pedal and it will usually go right in. Don't force it. Just a light pull or push and it will change gears. This is on of those deals that you want to just finese. Brian
/ HST gear range L-M-H select issue #9
When this happens while in four wheel drive it might be drivetrain wrap up that is causing some of the problem. It is important to have proper air pressure in the tires to keep this from happening.
An easy way to see if this might be the problem is to lift the front with the loader and see if the front tires spin. If so then adjust the tire pressure so that the front doesn't spin or spins very little. This also will make it easier to engage and disengage the four wheel drive.
/ HST gear range L-M-H select issue #10
I feel like a dummy for asking this question, but how can adding air to the front tires while they are raised with the fel make the front tires harder to spin?
/ HST gear range L-M-H select issue #11
It won't make them harder to spin while suspended in the air by the FEL, what it will do is make the circumerence of the tires larger which will change the pressure on the drive train when the tires are in contact with the ground and in MFWD. :p
Troy
Ok, just glad to see it's not just me. I try to be patient, but shizzle, I get so frustrated sitting there pushing/pulling/yanking/steppin' on the go pedal etc. trying to get the dang thing going. Kubota really needs to check into this if they're gonna offer this type of tranny.
j
/ HST gear range L-M-H select issue #13
When this happens to me, I just put it back into the gear I took it out of and then try again and it slips right in. Doing it this way has never failed yet.
/ HST gear range L-M-H select issue #14
When my L3430 doesn't want to shift I put it back into the gear I was in and reverse direction slightly before trying it again. 99% of the time it slips right into the gear I need.
I usuall have to do the same thing to shift from 4wd to 2wd.
/ HST gear range L-M-H select issue #15
I just move forward and backward in my seat to shake the tractor a little and it pops right in.
/ HST gear range L-M-H select issue #16
Clutch engage,take foot off brake let tractor roll very little,or turn steering wheel Lor R....works for me.
/ HST gear range L-M-H select issue #17
When tires spin while raising the front of the tractor while in four wheel drive it is because of axle wind-up. It is because you don't have a good relationship of the axle turns between front and rear axles.
Adding air or letting some out will balance it most of time unless there is a miss match of tire sizes and makes.
/ HST gear range L-M-H select issue #18
I have had this happen a few times.. today's 4 hours I shifted nearly flawlessly everytime...
BUT I have almost 200 hours on mine now..
It was tougher near the 50 and 100 hour marks...
Later,
J
