Towing?
/ Towing? #1
bigdave258
Louisiana
I have a F-150 w/ 5.3 8 cyl. pulling an 18 ft. dove tail w/ a 440 CT-(FEL-Bush hog 5') seems to work ok but i was thinking about upgrading in a used vehicle. Does anyone have any suggestions about the best way to go and yes i'll be looking for a diesel around the 1999/2005 year.
/ Towing? #2
If I were you I would look for a 2001 through 2003 Ford F350 with a 7.3 Power Stroke or a Cummins powered Dodge of the same years. With a Dodge its a crap shoot on the auto tranny. Thats why you see so many that are sticks. Same can be said with the Ford of that year range. With the Fords the 6.0 engine has a much better tranny and has been as reliable as anything out there. I would get a SRW truck and skip the 3/4 ton all together and get a 1 ton. If you get into a 6.0L Ford stay away from 2003 and 2004 models. The 2005 and later 6.0's were great but its a crap shoot on the earlier ones. That said I have a 2004 that has never been in the shop a day.
Chris
/ Towing? #4
Unless you have a personal preference against them, don't overlook the GM 2500HDs with the Duramax/Allison combo. They're good trucks too--easily competitive with Ford and Dodge diesels of the same vintage. Others may disagree about GM vs Ford vs Dodge, but the Duramax didn't vault GM into contention in the diesel wars for no reason at all.
/ Towing? #5
Chris
its really a shame, because the 7.3 was such a great motor, but the tranny's they're hooked to are piles of crap. the 6.0's definately had a lot of problems, but i think diamondpilot is right in that the later ones were better. i'd also agree on the 1 ton vs 3/4 - the price difference in the used market is usually very small, and the difference in build is fairly substantial.
that said, i'd include the chevy/gmc and dodge in your search. of the 99-05, i'd lean towards ford or dodge in the 99-03, but in the 04-06, i'd lean towards the chevy w/duramax/allison. the 06 chevy's forward include a 100k mile engine and trans warranty, and they have been proven reliable over the long haul. IMO, the chevy/GMC's are the best over-the-road haulers, but the least capable offroad - the independant front suspension hampers them there, and they are sprung and damped the softest. makes for the best on-road ride, but limits their capabilities offroad. they also are the quietest, a big factor in my decision to buy a chevy diesel.
i'm not brand-loyal in the least - i buy what best fits my need at the lowest cost. much like the tractors themselves, the best starting point is really defining what you want to do - dig 10' deep holes, or mow the lawn. not many machines that can do both will do either as well as a specialized machine.
ahm
/ Towing? #6
I was in your shoes about a year ago. I had a half ton chevy from 1998 to tow a 7000 tractor trailer combo on a 10k rated trailer. It worked OK but the truck was being used to its max. Also it was an extended cab and I have two girls with legs that are getting longer every day so I "needed" a crew cab. I wanted a newer 2003-2006 dodge with cummins becuase 2003 was the first crew cab for dodge. Those dodge trucks run about 20,000$ and up. The same thing in a chevy is even more expensive. In my experience all used Dmax trucks are significantly more expensive than the equivalent truck from another brand.
I found a 2000 ford crew cab by accident for about half of that with the 7.3 and bought it up. I'm not brand loyal but I do know that every brand has their good models.
The 2000 model year should be added to Diamond's list as it is the same as the 2001-2003 trucks if not better since the engine still has forged rods. Definitely get the 7.3 engine in the ford. It's been great. I get slightly better mileage in all driving conditions with the 7.3 diesel than I did with the 5.7 gas engine on my chevy.
2026 Kearney 102"x36' Gooseneck (A60462)
2026 Kearney...
2022 Forest River Wildwood 170SSX (A60463)
2022 Forest River...
2014 JLG 10054 SKYTRAK TELEHANDLER (A60736)
2014 JLG 10054...
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A61568)
2006 Ford F-150...
Mini concrete mixer (A61567)
Mini concrete...
