molly or QA forks for kiot loaders
   / molly or QA forks for kiot loaders
wow, I forgot about this. Well, as it is over a year later, I broke down sometime last year and bought some 48" QA pallet forks from my dealer. They were expensive, but they are also used frequently. Much more frequently used than I had originally thought. I don't know the name of them, or their weight rating off the top of my head. I could post a pic of them as they sit outside, but who hasn't seen forks before.
I actually have had some difficulty with dropping the bucket and attaching the forks, as the QA lever keeps dropping on me. Now I use a bungee to hold the lever straight. All in all, if they wear out before I die I will be surprised.
   / molly or QA forks for kiot loaders #12
I have the same problem and less than satisfactory solution. Trouble is that the angle of the lever when open is such that the bungee slips off unless I wrap it around a couple of times. PITA. I keep meaning to weld a washer to the handle so I can hook the bungee in place. Now you've reminded me that I forgot to do it again this weekend.:eek:
Hey IT, I use a small rubber bungee that has decent s hooks on them, and not one of the plastic hook cheap kind. This may solve your issue without having to do any welding.
when open/up my lever is almost straight up in the air.
   / molly or QA forks for kiot loaders #14
My lever is not straight up when open and it tends to fall partially closed unless I restrain it. I'll keep your suggestion in mind but may try to justify the purchase of a fancy portable welder by using it to tack a washer on':eek:
When you lock your implement onto the QA, is your lever all the way down (the one on mine locks down)? I wonder if you can adjust the lever? Just thought I'd mention it. It may be a difference between models, but I wouldn't think so.
I do appreciate the idea of purchasing a welding rig for a washer:D
   / molly or QA forks for kiot loaders #16
Nah, already had the welding rig but the washer provides justification in hindsight.;). Let me see, to fix this would require welding a washer and if I didn't have a welder I'd have to get the tractor off the island, to a welding shop, pay for a minimum welding charge then get the tractor back to the ferry and back on to the island. I'm figuring about $300-500 mostly for the transport. "So, you see honey, I've already paid for half the welder.":)
   / molly or QA forks for kiot loaders #17
If you don't have a welder you could just grind a slot into the back side of the lever for the bunge to hook to.
   / molly or QA forks for kiot loaders #19
Are you trying to get me in trouble?:p
Trouble? No, why would ya think that:confused: A washer welded on is a fine idea, I was just sugesting an alternative:).....I do have an off the topic question for ya though. Are the "clear" feul bowls clear like a drinking glass? I believe my dk40se has the "white" bowl, but I can still see through it. Since I've never saw the crack prone clear ones I have nothing to go by. TIA
   / molly or QA forks for kiot loaders #20
I went back and re read the last few posts, now I see....in trouble by your wife...LOL
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
Skid Steer 66in Skeleton Bucket (New/Unused) (A59225)
Skid Steer 66in...
TEST YOUR BID BUTTON! (A58374)
TEST YOUR BID...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
2018 Deere 323E (A53317)
2018 Deere 323E...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
