molly or QA forks for kiot loaders
   / molly or QA forks for kiot loaders #21
HI PA,
with a DK45 I would go with the skidsteer type forks. They are a little more expensive, but have a lot more strenght and they are adjustable.
I sell a lot of the clamp-ons from 1000 to 2000lb capacity on tCK series tractors. On the DK series I always sell the skidsteer mounted. With the loader capacity you have you will be tempted to try to pick-up heavier loads and I don't think the clamp-ons are stable enough to be safe at a ton or more. You will be a lot happier with the true forks with fence.
You should be able to get a good 3500lb set for around $800 or so.
Good Luck
KiotiDave
Thanks Kioti Dave, but my OP was almost 2 years ago. Somehow this thread re-emerged. Since that time I have bought some QA forks, 3500lbs and use them all the time. I think I am happier I did not buy the molly forks, as I have used the forks with web straps to move some rather large sized rocks around on my property (for walls and such). I think your advice is dead on and would advise others the same way. I bought my forks for a little under 700 if I remember, not sure of the manufacturere though. Bought them from my dealer as he is destitute:D Poor guy never has anyone in his lot:D
PORTABLE HAY FEEDER TRAILER (A52708)
PORTABLE HAY...
2006 Wells Cargo 16ft T/A Enclosed Cargo Trailer (A55973)
2006 Wells Cargo...
2005 TerraGator 8104 (A55302)
2005 TerraGator...
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2020 FREIGHTLINER...
