Posthole Digger Worksaver model 500 PHD
/ Worksaver model 500 PHD #1
Eric_Phillips
Rochester, NY
FarmTrac 270DTC
I have a used PHD that I think is a model 500. The shaft coming out of the gear box to the auger has two holes offset 90*. The augers also have these two holes. Are they both supposed to get a 1/2" shear pin or just one? There is a sleeve around the bottom of the shaft containing the lower hole that is the ID of the auger. If I only use one pin does it matter which hole?
/ Worksaver model 500 PHD #4
My worksaver PHD came with some grade 8 blots in those holes... shear pin is on the pto shaft.
1999 FLATBED TRAILER 15ft (A61569)
1999 FLATBED...
UNUSED ATS ME18 MINI EXCAVATOR (A62130)
UNUSED ATS ME18...
2021 John Deere 6120M Tractor (A63109)
2021 John Deere...
UNUSED GIYI 29" MINI HYD SIDE SHIFT PALLET FORKS (A62130)
UNUSED GIYI 29"...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
