Lets talk sun shadex
/ Lets talk sun shadex #1
SunnyJim
NENC
Lets talk sun shades
The OBX area maybe nice for tourists and beach go-ers that like to frolic in the ocean but for those of us on the tractor its just a bit to hot and sunny. Because of this and the viscious sun burn I got this past weekend I was thinking sun shade.
So who has one on their CK and if possible any pics? I am concerned with durability, I have some rather bushy trees that will not be coming down (I just love the shade they provide to much when I'm working) and storage since I have been folding my ROPS and parking the tractor in my detached garage. I will be adding a steel carport shelter with sides for the tractor at some point from these guys most likely STATELINE BUILDERS - Steel Strutures.
The next problem will be diverting the heat from the tractor away from me.
/ Lets talk sun shadex #2
I have an orange plastic Kioti sunshade on my DK40se. Works very well. I whack it frequently and unintentionally into overhanging branches. I've managed to put two small cracks into the raincatcher lip but otherwise it has held up just fine. Haven't tried to repair the lip yet but may try a plastic welding system one of these days. Overall it is a perfectly satisfactory product and worth the $300 and change. Were I to do it again I'd probably get the same thing. If I had unlimited funds I'd probably have a full FROPS made up and use steel but I am satisfied with what I have. Much better than no sunshield (been there done that).
Thanks Island that's what I wanted to see. If the CK unit was 300 and change I'd be all over that. I called wallace for a quote and it was $450 and LTL.:eek:
/ Lets talk sun shadex #4
I guess they've gone up in price. It is a nice unit though, not sure you are going to find anything as durable for less. There is one company that specializes in these things, cannot remember the name but searching on TBN will help you find it.
/ Lets talk sun shadex #5
Try this link: Item
The recent discussion of these sunshades/canopys on TBN suggests that the aluminum diamondplate models may be more durable....
That is one person's opinion who used to work for a dealer who sold/installed them.
Do a search of TBN to find the thread.
I think it was under customizations category of main forums.
/ Lets talk sun shadex #6
Hi,
Check out That tel-trax link(posted above) and look at the aluminum diamond plate. It is a nice unit I have sold 2 of them and you can get a universal mount for it to fit any size ROPS. I had good service and prompt shipment. The only thing I had to do was glue on the rubber molding around the edge.
My customers love it and no chance of cracking in cold weather.
KiotiDave
/ Lets talk sun shadex #7
Hi,
Man, that website reminds me of the early 1990's:eek: with regard to web design. It is hard to figure out much of anything other than their contact information and a few photos. Looks like a nice product though.
/ Lets talk sun shadex #8
Re: Lets talk sun shades
I bought a wells ag canopy for my DK 40se and love it,there are quality made steel construction.coobie
/ Lets talk sun shadex #9
I bought the kioti orange plastic thing, and I'm not crazy about it. It does shield the sun, and it hasn't broken from tree limbs. My problem is that even with the rops all the way back, it won't fit in my garage. So it is a large PITA to take on and off. I did learn a little trick to it though, I use a cabinet jack (for installing cabinets) on the deck of my tractor when I install those brackets. It's not that heavy, but wind can make it a real PITA. So, I use an addtional clamp from the rops to the shade while installing th brackets. All in all, it's not that difficult anymore.
I may have to come up with a quick disconnect for this, but haven't had time to play with it. Keep your garage height in mind when puchasing the product. If you have 10' doors you will likely not have an issue.
/ Lets talk sun shadex #10
Wells Ag, it is rated to stop something falling on you, I got the painted steel and put a yard sale basket underneath.
Mike
/ Lets talk sun shadex #11
So, is your problem with the sun shade or your garage door?;)
I solved that problem another way ;):
/ Lets talk sun shadex #12
Nice! I see you barely have room to get that rig in there. I suffer from the same issue.
I can't see chopping up my pole building to add new garage doors. I might extend the back end of it and make that opening bigger, then I won't have an issue with the canopy.
Did you see some of the other canopies? Looks like they are side mount jobs and not top mounts, I just think if I would have held out longer and endured another sun burn or two, I would've found ones that would have attached and removed easier.
Oh well, live and learn.
/ Lets talk sun shadex #13
Not in person, just on the internet. I was actually more concerned about not hitting my head on the thing as I mounted (I'm 6'5") and I did not have a garage height issue to worry about. In the end it came down to taking what the dealer recommended and had in stock. I've been happy with it.
/ Lets talk sun shadex #14
Have any of you that have height clearance problems ever checked to see if you could fold down your ROPS with your canopy on? I had to do that with my Mahindra 7520 for awhile. There was juuuust enough clearance to be able to do that and not have the shade bind up on the ROPS.
/ Lets talk sun shadex #15
didn't work for me. Kioti's rops lay/tilt backwards on my tractor. My old CC tractor rops use to fold in half, which would work with a shade and my garage door clearance.
2025 JMR 72in. Hydraulic Dual Cylinder Brush Grapple Skid Steer Attachment (A61572)
2025 JMR 72in...
JLG HC3 8ft Boom Lift Man Basket Attachment (A61572)
JLG HC3 8ft Boom...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
58in Padfoot Vibratory Roller Skid Steer Attachment (A61572)
58in Padfoot...
2018 New Holland C227 Compact Track Loader (A63689)
2018 New Holland...
John Deere 6110M (A60462)
John Deere 6110M...
