Kioti or Kubota ???'s
/ Kioti or Kubota ???'s #1
B52
Member
southwestern NYS
Kubota B2620 ; also 1939 AC model B
I'm close to buying a new Kubota B2620 (w/FEL), but I'm also eyeballing an equivalent Kioti. I've owned a Cub Cadet 27hp 4wd and equivalent Kubota in the past, but zero experience with a Kioti. All I know is that they're made in S.Korea. I know nothing of their reliability or quality. Can you guys help me out here ? Is there anything I should be aware of ?
/ Kioti or Kubota ???'s #2
Mine is a 2004 with 875 hours, perform regular fluid changes and the only problem I've had is a broken seat mount which was replaced under warranty. I looked at Kubota and Kioti and in my opinion I ended up with a lot more tractor for a lot less money.
/ Kioti or Kubota ???'s #3
I have had my DK35 HST for 65 hours now (over a year) and I LOVE it. I have had no issues whatsoever. Plus I saved about $5000 over the equivalent Kubota and got more HP. Not to mention the better warranty, which I have yet to use. I have not had a job too big for this beast yet. The loader had a higher capacity than the Kubota and Deere.
Big thing is find a dealer you like. Mine wasn't so good and I had to switch. I wish I would have switched before I bought. Good luck and either way, I think you'll be happy.
/ Kioti or Kubota ???'s #4
Am new to this forum and in similar situation as B52. JD compacts seem to sell on the name (which is the only thing American about them). My experience with JD garden equipment/tractors is they really price up the parts/service. A friend with a fleet of JD compacts has had nothing but problems with his last. I know of nobody unhappy with a Kubota. Just yesterday I visited a Kioti dealer. Seems like a great dealer/shop. I am impressed with the Kioti looking specifically at the CK30 and 35 in manual and HST. Right now I have a Ford 2N and tired of babying it and nickel-diming. Like the frame, though.
Will keep and use present implements... single share plow, 5' bush hog, 5+' 3 pt disk, rear bucket scoop, 6' York rake, 6' rear blade, post hole auger. Want to add FEL, backhoe, tiller and new mower deck.
Have never used HST..... would like to hear about strong preferences one way or another. Any major disadvantages either way? HST does look like an easy rig.
The overall features of Kioti seem as good and better than Kubota. Like quick disconnect loader bucket. Backhoe seems like a good mount system. I think I prefer the LandPride affiliation that Kubota has, though. Kioti does not offer a reverse rotation tiller...only forward. Anyone out there can vouch for the Kioti implements?
I especially like the ruggedness of the Kioti CKs...axle housings seem much better made cast. Overall tractor is about 50% heavier.
Both kubota and Kioti offer front weights. Only Kubota has a ballast box...would like to consider that rather than filling tires.
Anyone strongly prefer Ag or industrial tires? I garden 2 -3 acres of produce curently. Will use new tractor for grass mowing as JD garden tractor is done for. Don't want to be too harsh on turf but concerned that industrial treads will fill up too easily in loose/wet soil. On the other hand, I treat a lawn as a utility rather than a place to use $K on chemicals...I'd rather eat my dandelions than poison everything.
What about belly vs. rear hitch mower deck? 30 vs. 35 HP?
Yeah...this is loaded with questons and I can probably spend all day researching other posts.
Would appreciate any input!! Ag....
/ Kioti or Kubota ???'s #5
I have a CK25. It's been a brute of a tractor. For ground engagment work, the weight and hydraulic flow of the Kioti is hard to beat. Mine is a 2006 with 330 hours. I had the old style loader problems, and just recently my injector pump failed. Kioti did me right on the loader (thanks to the dealer) and I think they are going to take care of the pump too. The new loader is very strong and supposedly there have been changes to correct for the pump failures. Search on here and you'll quickly see where the issues have been/are. All-in-all, I'd say it's a well built quality machine that has had some design flaws in the earilier model years. Most of these have corrected on the new models.
I pressume you are looking at the CK's. If you plan to do a lot of loader or ground engagement work, I'd go Kioti. The L39 is really more along the lines of the CK's wrt to digging capability (at something like twice the price). OTOH the B2620 is an excellent all around machine where mowing is a major task. The CK's are fine for bush hogging. But, for finish mowing I'd pick something lighter.
The most important thing is buy from a good dealer.
/ Kioti or Kubota ???'s #6
The Kubota B2620 is a really nice machine that is optomized for lawn mowing and general utility work. The Kioti equivalent for comparison is a bit hard to determine however. The CK20 is about the same frame size but has fewer horsepower and only a two speed hydro. The CK is still heavier and has a significantly more powerful loader than the B2620. The Kioti CK27 is about the same horsepower as the Kubota but is much more tractor in every other way including being substantially heavier.
I've owned two Kioti's (CK20 and DK40se) and bought them both over the rough Kubota equivalents each time because the value was just better for the dollar. Kioti's suffer in comparison with regard to numbers and experience of convenient dealers (general point, specifics vary) and with regard to resale value in the first three or four years. However, the resale argument is not much of an issue if you don't plan on selling and if the Kioti costs less to begin with. I lost a total of $2K from my original purchase price when I traded in my three year old CK20 TLB and might have sold it for more if I'd chosen not to trade).
If you are primarily mowing then there is no reason to have other than a light weight tractor to begin with and I'd own a B2620 happily if that was my situation. If ground engagement or loader capacity is important then the Kioti's stand out above the equivalently priced Kubota. I paid about what a B3030 cost for my DK40se and there is simply no comparison when comparing specs as a compact utility tractor. Still, if I were mostly mowing lawns, I'd have gone with the B series.
/ Kioti or Kubota ???'s #7
I have 1260+ hours on my DK35.
It has been very good machine for me so far. Very pleased with it.
/ Kioti or Kubota ???'s #8
For what its worth, I bought my Kioti without ever having heard of the brand prior to seeing one at my local dealer, (who I thought sold Kubotas due to the color similarity) when driving by at 50+ mph.
Anyway, after test driving a DK 35se/hst I bought it no questions asked, because of the 4 year warranty, features, local dealer, ability to get what implements I wanted without having to be too concerned that I might need a more powerful rig soon after buying it, etc.
Have put about 50hours on in last few weeks digging sono tube holes, removing the debris the road crew left piled in the ditches from mud season and moving all kinds of things into a dumpster to clean up my yard, etc. Backhoe works well, Bucket is great, and pallet forks are terrific. Haven't used box blade or new model DR. 3pth chipper yet...
I'm more than happy with it- and BTW, I have used Kubotas and Fords in the past for people I used top work for; and I just thought the Kioti was more machine for what I was willing to pay.
I don't think you will be disappointed in purchasing a Kioti.
Good luck...
/ Kioti or Kubota ???'s #9
...after test driving a DK 35se/hst I bought it no questions asked, because of the 4 year warranty,..
4 year warranty?? I thought these had only 24 months!! I was on the website earlier today...saw nothing of a 4 year warranty.
I also have a concern with current sales promo. I called Kioti HQ and believe even they were confused.
Right now you can get up to 60 mos at 0% with 0 down OR receive a $1500 rebate/credit. Another offer, independent of financing issues, is a free FEL with any CK or DK. Not a bad incentive!!
The dealer told me the FEL deal is only available if you pay cash. That's not what the website says...think I'm being given a song and dance. Anyone know better??
/ Kioti or Kubota ???'s #10
1st 24months is "bumper to bumper" (except wear items)
Second 24 months is parts and labor on drivetrain.
Warranty Link
On the financing and such--
You can get the free loader OR cash back OR the low rate financing but only one of the promotions.
Can't pyramid them. :D
I wish we could I'd by one for myself. :D:D:D
USA Financing link
Disclaimer at bottom of cash rebate incentive "Block"
All financing is subject to credit approval by KIOTI Finance.
Other conditions may apply.
Each finance program is independent from the other programs and may not be combined in
any manner."
That darn "Fine Print" LOL
BTI
/ Kioti or Kubota ???'s #11
Hi Agrarian,
To get the Free loader on CKand DK-SE models you do not have to pay cash. You can use agricredit financing, but you must use their standard rate. OR.... You can get 0% for 60 months OR 2.99% for 72 months OR 3.99% for 84months(these rates are subsidized by Kioti from the standard Rates) OR you can take a rebate if you do not want a loader.
Like BTI says, you may not combine any or these choices.
Good Luck,
KiotiDave
/ Kioti or Kubota ???'s #12
Hi Agrarian,
Good Luck,
KiotiDave
Take the loader, it is the best deal. Costs about 3500 I believe at least at list so it is worth considerably more than the rebate and finance charges.
/ Kioti or Kubota ???'s #13
Take the loader, you can pay with whatever you like, including but NOT limited to cash or a combo of cash and whatever- I took the loader and the web site details the 4 year warranty under the heading: KIOTI TRACTOR LIMITED WARRANTY in a section under the warranty tab referred to as Kioti's new full fleet warranty which superseeds the prior warranty coverage, (of 2 years) which ran PRIOR to Feb 16, 2006.
The new warranty is for all Kioti tractors for any type of use, and includes engine and drive train...
details of same below:
And I quote: "Effective January 22, 2008
A. General Provisions
KIOTI Tractor provides the warranties described below to the original purchaser of any new KIOTI tractor, implement, or part purchased
from an authorized KIOTI dealer. KIOTI also allows the transfer of the tractor痴 warranty to any subsequent transferee. (Tractors, loaders and backhoes only, excludes all other attachments and implements) KIOTI will repair or replace, at its option, any part covered under this
warranty that is found to be defective in material or workmanship during the applicable warranty period. In order to obtain warranty repairs, the purchaser must deliver the product, at the purchaser痴 expense, along with proof of purchase to any authorized KIOTI Tractor dealer.
B. Warranty Coverage
1. General Warranty This general warranty applies to KIOTI products for the following periods.
The warranty period begins on the date of purchase and is activated by receipt of an executed Warranty Agreement.
PRODUCT TERMS OF WARRANTY COVERAGE
Tractors 24 months Parts and Labor
Front-End Loaders, Backhoes and Implements 12 months Parts and Labor
Replacement Parts 3 months or the remainder of the unit warranty, whichever is longer Parts only
Replacement Engines 12 months Parts and Labor
2. Extended Warranty The Extended warranty applies to new tractors and runs concurrently with the General Warranty.
Engine* and drive line** 48 months Parts and Labor
* The engine includes the crankcase, cylinder head, front gear case, valve cover pans, and all parts contained therein. Does NOT include fuel,
electrical, cooling, intake, and exhaust components.
** The drive line includes the clutch housing, transmission case, differential and final drive housing, and all parts contained therein, plus drive axles and external drive shafts. Does NOT include drive clutch disc or PTO clutch disc (wet or dry)
C. The General and Extended Warranties do not cover the following:
1. Physical abuse or misuse of the product or operation of the product in a manner contrary to the provisions of its owner痴 manual.
2. A repair made or parts replaced or modified by anyone other than an authorized KIOTI dealer.
3. Damage caused by the use of any non-KIOTI front-end loader, backhoe, attachment, implement, accessory or part.
4. Normal wear items such as, but not limited to: bushing, cutting edges, cutting blades, cutting teeth, drive chains, drive belts, clutch
disc, operator痴 seat, and brake lining.
5. Parts and materials considered normal maintenance items including, but not limited to: filter elements, lubricants, coolants, light bulbs, and belts.
6. Tires, tubes and batteries. The original manufacturer痴 warranty covers these items.
7. Used products.
8. Addition or replacement of chemical weight materials.
9. The following services and labor related items: parts cleaning, adjustments, diagnostic, tune-up, overtime, pickup, delivery, and travel time.
D. The warranty for any tractor immediately terminates if any of the following occur:
1. Starting fluid or Ether is used to start or run the engine;
2. Any replacement parts used on the tractor are other than genuine KIOTI brand parts;
3. Any repair made or parts replaced or modified by anyone other than an authorized KIOTI dealer;
4. Physical abuse or misuse of the product or operation of the product in a manner contrary to the provisions of its owner's manual;
5. Adjustments are made to the injection pump fuel delivery system; or
6. Regular maintenance and service is not performed as prescribed by the operator痴 manual during the warranty term.
E. The Implement and replacement part warranties terminate if any of the following occur:
1. The replacement parts are other than genuine KIOTI brand and are installed by a non-KIOTI dealer; or.
2. Regular maintenance and service is not performed as prescribed by the operator痴 manual during the warranty term.
F. Limitations of KIOTI痴 responsibility on products used for personal, family, or household purposes:
Any express warranty not provided herein, and any remedy for breach of contract which, but for this provision, might rise by implication or
operation of law, is hereby excluded and disclaimed.
ANY IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE EXPRESSLY
DISCLAIMED.
Under no circumstances shall KIOTI tractor be liable to purchaser or any other person for any special or consequential damages, whether
arising out of breach of warranty, breach of contract or otherwise.
Legal rights vary from state to state, so the above limitations may not apply to you if precluded by local law.
G. Limitations of KIOTI痴 responsibility on products used for rental, commercial, Industrial or agricultural purposes:
This warranty is in lieu of all other warranties, express or implied, and any other obligations or liabilities on the part of KIOTI Tractor. ALL WARRANTIES OF MERCHANTABILITY AND OF FITNESS FOR A PARTICULAR PURPOSE ARE EXCLUDED. KIOTI Tractor will not be responsible for any incidental or consequential damages, including but not limited to, commercial loss, inconvenience, loss of equipment
use, loss of profit and loss or damage to crops which may result from the purchase and use of KIOTI products.
H. No modification of Warranty
This warranty is the only warranty authorized by KIOTI Tractor. Neither the KIOTI authorized distributors, dealers, nor any other party has any authority to make representations on behalf of KIOTI Tractor to modify the terms and limitations of this warranty.
I. Product Improvements KIOTI reserves the right to make changes to its products at any time without notice and without incurring obligations with respect to making
the same changes to products manufactured prior to this date of change.
J. Arbitration By acceptance of the product and by receipt and acceptance of this Warranty Agreement, and execution thereof, the purchaser hereby agrees that any dispute, claim, controversy, cause of action and/or demand related, in any fashion, to this Warranty Agreement and/or the Kioti product shall be subject to arbitration. Said arbitration shall be conducted in a manner similar to the processes, procedures and regulations set forth by the American Arbitration Association (the "AAA"). Nothing in this clause and/or Warranty Agreement shall require a matter to be filed in the AAA. By acceptance of the product and this Warranty Agreement, the purchaser hereby voluntarily subjects
himself/herself/itself to the jurisdiction of the chosen arbitrator and arbitration proceedings."
So the question becomes or for that matter the answer is- Why buy a Kubota when you can get a 4 year warranty on a KIOTI?
Hope this helps.
CM
BUNDLE OF 10' RE BAR (A62131)
BUNDLE OF 10' RE...
2016 Dodge 5500 Box Truck (A63116)
2016 Dodge 5500...
1952 Army Jeep M38 (A61166)
1952 Army Jeep M38...
2015 Volkswagen Passat Sedan (A61569)
2015 Volkswagen...
2023 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2023 Peterbilt 567...
Rooster Weathervane (A61569)
Rooster...
