DK45S/10k Trailer
   / DK45S/10k Trailer #1
wingbone
Kershaw, SC
Kioti DK45SE
I will be buying a used DK45S in a week or so and have started trying to find a used trailer for it. I had really planned on trying to go ahead find something a little bigger than a 10k trailer. I will be pulling the rig with an older, medium duty dump truck. In looking at the larger rated trailers, it looks like they make a pretty hefty jump in construction at that size which is going to be pushing me as far as the GVWR, plus, I have seen a lot more 10K trailers for sale closer to me. In estimating the weight from reading on here and the Kioti site, this looks like what I will be face with:
Tractor: 4300lbs
Tires already filled: @ 1100lbs
Loader@ 1000lbs
Eventual attachments: Bush Hog @ 700lbs(just looked up BushHog 720 weight)
Totals roughly 7500lbs.
It looks like some estimates I've seen on 20-22 foot 10K trailers is around 3000lbs so this puts me right on the weight(it seems most trailers list 10,500 capacity). Since this is right at the top of capacity and there will usually be a few miscellaneous items, can I figure in that the weight the vehicle will be carrying on the tongue will relieve some of the weight on the trailer or is this just trying to cut it too close. Obviously, I don't think it's there's going to be an exact cut off at the rating, but would it be a lot better to wait it out and find a larger trailer.
Some of those 14k trailers look really heavy themselves. Do many of you guys haul your DK45's with 10K trailers?
   / DK45S/10k Trailer #2
Wingbone, I use a Bigtex trailer rated at 10,000 lbs to haul my DK50c with loader & backhoe. I pull it with an E-350 4x4 van. I've never had a problem I weighed the trailer at work an it was around 1,600 lbs. If I had pictures I would post. Good luck. Frenchie.
   / DK45S/10k Trailer #3
I think a 10K for a DK50 with loader and backhoe is stretching it. I'm currently looking for a trailer for my DK45s and decided a 12K is the minimum. It's definitely noticeable when comparing the construction of a 10K and 12K.
Typically a 10K weighs 2000# with a payload of 8000# and a 12K 2500# with a payload of 9500#. I've run the numbers over and over again and a 10K won't cut it for me.
Tractor = 4400#
Ballast = 1000#
Loader = 1000#
Backhoe w/sub frame mount (Woods BH90-X) = 1850#
Total = 8250#
Then how many of us really just want to haul just the tractor. I know I'll want to pack my box blade (800#), disk (800#) and pallet forks (400#) occasionally. I've decided on a 14K registered as a 12K for not having or need a CDL. I'll be towing with a 2007 Dodge 1 ton dump. The 12K registration will keep me under the total 26K requiring a CDL.
   / DK45S/10k Trailer
I had originally decided on at least a 12k or even a 14k but I really want to buy a used trailer and the 12's aren't real common. Most of the 14k trailers look a lot beefier and take a big jump in weight. It seems like you would only be getting a little more payload capacity but be adding a lot more for your vehicle to tow. I have seen a few trailers like a PJ that still 'look' more like a medium duty but have dual 7k axles. That's the kind I would really like to find.
   / DK45S/10k Trailer #5
Tractor = 4400#
Ballast = 1000#
Loader = 1000#
Total = 8250#
You can't dodge A CDL with downrated registration IIRC
   / DK45S/10k Trailer #6
Been pulling my dk45s with a 10,000 trailer with no problems now for three years. I usually have the loader and one implement on the three point. Trailer weighs 1400 lbs.
Dan
   / DK45S/10k Trailer #7
Before I bought my gooseneck trailer I pulled around my DK45s on an 18', 12,000 GVWR trailer. It did a great job with the weight but was really too short with FEL and a 7' bush hog attached. 25' gooseneck solved that problem.
   / DK45S/10k Trailer #8
I own an 18' PJ trailer rated for 10,400#. It uses a pair of standard 5200# dexter axles and is built of stout 6" channel. I love the trailer and use it for my 4500# CK30 as pictured since a 7000# rated trailer would have been near the max with my tractor.
I have actually weighed the empty trailer at real scales and it weighs 2500#s. For an 8000# cargo capacity.
I like having an extra margin of safety when setting up this kind of gear and I have been happy with my choice of going a step bigger than needed.
Could you unfill the tires? These Kiotis are awfully heavy as is.
   / DK45S/10k Trailer #9
   / DK45S/10k Trailer #10
Manufacturers will tag the GVRW upon request to 12k on a 14K constructed trailer. BTW, I ain't hauling my tractor with a trailer only weighing 1400#!
CAT 289D3 (A58214)
CAT 289D3 (A58214)
2012 Kenworth T800 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2012 Kenworth T800...
2005 CHANDLER  500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
CAT 777B ARTICULATED DUMP TRUCK (A58214)
CAT 777B...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56435)
Neckover GL24-2-7K...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
