Steers like a BARGE!
/ Steers like a BARGE! #21
Chris. I'm pretty sure your intentions are good. But the fact that you even have to ask that question, is proof enough that you've never even seen one of these TS-series.
I own one, Chip services them. Is it that difficult for you to just watch for a change?
//greg//
Guess the squadron flew right over.
My question wasn't of a technical nature to eliciting mechanical advice on the process to break the lines down... whether easy or extremely difficult in a chinese free-labor assembly line kind of way..
it was more rhetorical as in.. 'dang it man.. how hard is it to pull the lines and check it' sort of thing.
It's a sure fire -go/no go- way to tell if a cyl is bypassing internally while waiting for the answer to come over the magic 8-ball, ouija board, or internet.
As for not owning a chinese tractor.. that's a tired old comment. I've said it half a dozen times.... either make this sub an owners forum -only-, and -close- it to -all- non owners.. or don't gripe about non owners posting comments or opinions here..
soundguy
/ Steers like a BARGE! #22
Can they be repaired or do I need to buy one? What parts and cost, or how much is the pump?
Since Chip may be taking advantage of the holiday weekend, I'll take the liberty of responding. Some pump issues are repairable, but I'd remove/clean/inspect before assuming anything. The PR (pressure relief) valve may simply be obstructed, and a good cleaning might fix it. The PR valve is (should be) adjustable as well. Plus - once removed - the pump tang and drive assembly receiver are clearly visible. If the receiver is stripped, the pump itself might be perfectly good. But if the tang is rounded off, you may as well order a new pump. Worst case scenario, they destroyed each other; new drive gear receiver, new pump.
Let's hope you don't need a new pump. But if you do, be aware that there's more than one version in that capacity. Take care to get one with an internal PR valve.
//greg//
/ Steers like a BARGE! #23
Rather than just replace the pump, (we have it in stock, back to work Tuesday). it may be worth while to see if the pump is pumping, if the PR valve in teh pump is stuck or if the drive tank is damaged. the latter requires removal of the pump to inspect. Sometimes you can tap on the pump body with something and get teh PR valve to reseat. otherwise dissassembly and cleaning is the plan.
/ Steers like a BARGE! #24
Just trying to catch up and stay on the same page on the lingo here.. are we talking about a priority valve ?
soundguy
/ Steers like a BARGE! #25
soundguy
No. They're only used to split off sub-circuits, like for steering on the one-pump Jinmas. This is a two pump TaiShan. I thought I was pretty clear in identifying it as a Pressure Relief valve.
//greg//
/ Steers like a BARGE! #26
//greg//
Oh ok.. I was actually responding to bluechips message under yours, and didn't see your (pressure relief) in quotations.
The reason I asked, is since we -were- talking about power steering, since a priority valve is used in some systems for ps pressure off a multi-used pump.
soundguy
/ Steers like a BARGE! #27
soundguy
Yes, Chris - we are talking about power steering. The relief valve under discussion is internal to hydraulic pump that powers the steering in LakeSpirit's TS254. I have the same pump in both my current tractors. The one on the 454 is problematic when overheated - also a pressure relief issue - the one on the 354 works just fine.
//greg//
/ Steers like a BARGE! #29
Why are you being a jerk about this?
Matter of perspective I guess. From mine, I'm trying to get across that this is obviously not a steering system with which you're familiar enough to be offering meaningful troubleshooting advice. That you are still trying - in spite of Chip's explanation why removing the hoses won't yield valid results - should speak for itself.
//greg//
/ Steers like a BARGE! #30
The part you are being a jerk about is when i'm asking questions to catch up you keep 'throwing lefts'
soundguy
I have been away, so haven't tried anything yet. Now, when I start the tractor and turn the steering wheel, it feels as thought there's a "chatter" but the tires do not turn.
2022 EZ-GO ELITE...
2008 Mercury Grand Marquis LS (A62613)
2008 Mercury Grand...
PAN (A62613)
PAN (A62613)
John Deere 230 Disk (A66285)
John Deere 230...
1987 FORD F-8000 ROLLBACK TRUCK (A64277)
1987 FORD F-8000...
Cattle Feeder (A65640)
