M7040HD Is there a hydraulic fluid screen?
   / M7040HD Is there a hydraulic fluid screen? #1
Hugenpoet
Doing my 50 hour service this weekend, at 65 hours like most things in my life, and while I have read about "cleaning the screen" when changing the hydraulic fluid on other models, the 7040 manual makes no mention of a screen only wiping the magnetic filter clean as part of the process. Any info/advice would be appreciated.
   / M7040HD Is there a hydraulic fluid screen? #2
I've done the 50 hr service on 2 of the xx40 series and have only found what you have already mentioned, the magnetic "stub" extending into one of the 2 hyd filters. Me thinks in Japanese translation, "filter" refers to the mag stub action you mention......in the 60's I bought an early generation Datsun PU truck....the manual said the electrical system operates on a 12 bolt system....maybe Japanese tech lit has come a long way?, or at least into our pocketbooks. bb
Thanks for the info. Makes tomorrow's project easier not having to deal with a screen.
   / M7040HD Is there a hydraulic fluid screen? #4
I don't know if your tractor has screens or not but the trend seems to be away from them in modern tractors. Post #12 in the thread below gives a good explanation why. Basically, static electricity builds up in the screens and solidifies the oil which then blocks the screen and starves the HST. (Another example of "It seemed like a good idea at the time".)
http://www.tractorbynet.com/forums/kubota-owning-operating/131019-b2710-hyd-strainer-2.html
   / M7040HD Is there a hydraulic fluid screen? #5
as a footnote on the hyd filters, on my 7040 one of the filters came off easily, the other was extremely stubborn and had to use 2 filter wrenches at once to finally budge it...think they put it on dry at the factory w/o fluid around the seal. hope yours goes smooth, probably will. am sure you already know to use UDT fluid. also once filled, extend & lower on your FEL and raise & lower 3 pt then check level again. double check ft axle level again after some use as things settle good luck bb
Thanks again.
   / M7040HD Is there a hydraulic fluid screen? #7
Hugenpoet: your hard work & financial sacrifice will yield you many awesome hrs. on this machine. you should fashion a poem in the 7040's honor...or at least christen her and have a few good fluids yourself in celebration.
good luck bb
197359 (A50458)
197359 (A50458)
4 1/2 150G DRILL STEM 358 JOINTS (A50854)
4 1/2 150G DRILL...
2010 Gleaner 9250 Draper Head  30' with Crary Air Wind System (A51039)
2010 Gleaner 9250...
2003 John Deere 1790 Planter (A50657)
2003 John Deere...
2019 VOLVO VNL HIGH ROOF SLEEPER (A50046)
2019 VOLVO VNL...
2016 Nissan NV200 Cargo Van (A50323)
2016 Nissan NV200...
