Chipper Video of my little chipper
   / Video of my little chipper #1
BigE_
Near Portland, Oregon
New Holland TC33D, LT4000
Made a video today of my little chipper in action. I just replaced the engine on it. It had a 25hp, but a new 25hp was around $3k all said and done. I put in an 18hp engine, seems to run just fine, and it was half the price.
Unfortunately, the battery on the camcorder died right in the middle, and by the time I figured it out, well, all the branches were chipped up. I'll try to do a follow up later.
YouTube - The little chipper that could
Enjoy,
-Steve
   / Video of my little chipper #2
Nice looking chipper, I'd like to have one like that, but tough to justify because I don't have frequent enough need.
I had a good burn last weekend instead.
Good luck with it.
Sounded like plenty of power, how big did you chip?
Joel
   / Video of my little chipper #3
Long as you chip small stuff like you were doing in the video, that 18hp should do just fine. The telling tale will be when you try and run the bigger stuff through it. Do you know what the max size material that chipper is rated for??
   / Video of my little chipper #4
Looks like a Bandit 65?
   / Video of my little chipper #5
I would love to get a pto drive chipper like that. I have been contemplating the best way to clear some land here at the house. It is infested with 4-6 inch pines that are next to impossible to push over or dig up with my FEL.
   / Video of my little chipper #6
I always like to wrk with someone when I chip, just in case something unfortunate happens. It looks like a good rig. Here is mine which can do 4" wood:
This is a ProMark 210 and can do up to 6". ProMark offered it with 2 different sized motors - a 25 hp and an 18 hp.
I put in a B&S Vanguard pro series motor.
When chipping the small stuff, I normally run it right around 2700 RPMs (idle is 1600 RPMs). If I have big stuff to do, I can crank it up to 3600 RPMs, where the max torque is for that motor. Actually, I've run 5" stuff through at 3,000 RPMs without any problems.
But, pretty much, anything 3" and above is firewood. If it is late in the day, it may become 4" and above, just because the small stuff is really a pain for firewood. You spend too much time cutting, carrying, and stacking it. Does make good kindling, though.
2023 John Deere 325G Track Loader (A53485)
2023 John Deere...
12" PIN ON BUCKET (A52707)
12" PIN ON BUCKET...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A55852)
2016 Autocar...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2016 Takeuchi TL8R2 Two Speed Compact Track Loader Skid Steer (A55851)
2016 Takeuchi...
EZ-GO Electric Cart (A55853)
EZ-GO Electric...
