Going to Sell The B7510. What's It Worth?
   / Going to Sell The B7510. What's It Worth? #1
robertm
Northern Illinois
Kubota BX2660
I have been contemplating downgrading to a BX for two years now. I finally decided to pass on the whole idea of getting an additional tractor to be a dedicated lawn mower and keep my B7510 for loader work. I don't have room, I don't need servicing two tractors, and I certainly don't need the B7510 sitting there just for loader work a few times a year. That would be unhealthy for my marriage. I will not do without a loader, however.
Because the B7510 is too intimidating for the DW to mow with, and the DS will be mowing in a year or so, am seriously contemplating downgrading to a BX2660 or a JD2305. I don't need the larger B7510, which really only seems to only offer more ground clearance over the BX. The extra 3pt lifting capacity of the B7510 will never be an issue for me, either, as the largest implement I'll ever use (if even I do) will be a tiller. The loader on the BX is close enough to the B7510 in capacity that my gravel, black dirt, mulch, and snow removal tasks will certainly not be compromised by the BX. I think the BX will be an all better machine for the DS to mow with, but still allow me to retai my loader capability.
So, in the round-about way of getting to the point, what is my B7510 worth? I have scoured the internet, and all the B7510's that were on there a few months ago are now gone. I have found a few, but they are listed at $12,000+. I can't see that is right, but maybe the economy has swayed the used values. I found two similar to mine on Ebay last week, but see they are now gone. Again, they were around the $11,500-$12,000 figure. Huh?
My unit is a B7510 with 220 Hours, the larger capacity LA302 loader with grille guard (not LA272), bar turf tires, 60" mid-mount mower, tooth bar, Land Pride 72" rear blade, Paynes clamp-on forks, extra set of mower blades, and a nice finished concrete ballast. So, if I can't find this animal on the internet, or any local dealers (any within several hundred miles for that matter), where in the world do I find a value? I was hoping to minimize by cash difference by downgrading, but who knows. Every used comparably equipped BX I find with comparable hours seems to be running $9,500+, so I figure the B7510 would be worth more than that. Am I wrong here?
I figure I'll dump the whole works and start with a new set-up with the loader, suspended mower deck, a lighter and more appropriate-sized rear blade, and a ballast box.
   / Going to Sell The B7510. What's It Worth? #2
Well the system in my sig/avatar is only a little larger. It's $11.5 before BH. But it's an awesome trailer. <250 hrs.
So, after I "un-ouija" the numbers, it appears that the dealer has offered me somewhere around $11,000 for my B7510 tractor (220 hours), Bar Turfs, 60" MMM, and FEL. That's based upon the best current price I see locally at $14,700 for a new BX2660, R4's (or turfs), 60"mmm, and FEL. I've heard of $13,900 on the board here, but everywhere I call within reasonable distance, the $14,700 is the best. I have one call I am waiting on from a distant dealer, and when I bought my current tractor, he was about $1,000 cheaper. If that's the case this time, I'll have to buy it there, if I decide to pull the trigger.
I could try to sell my tractor for $12,000 outright, but I doubt that's likely. Then I'd lose the sales tax benefit of paying only on the trade difference when trading. That's worth about $1,000, which would put me back to square #1 with no real savings. So, selling outright not be a great option.
So, a few questions:
A) What do you think?
B) Should I opt for the R4's this time? I have had both types of turfs (standard and bar types), and both tore up my lawn with the B7510.
I guess if the BX2660 is going to tear up my lawn regardless of tire type, I'd rather the more aggressive R4's for snow removal. Because I'm primarily doing mowing chores, though, maybe I'm stupid to consider R4's. One thing worthy of noting is that I see a few mild cuts and bruises on the surface of my current turfs - nothing compromising or deep for concern, but the R4's will hold up better when I start future projects. One dealer quoted me an additional set of turfs and rims for the BX for $300. Should I just consider getting turfs and an additional set of R4's for later, if needed?
   / Going to Sell The B7510. What's It Worth? #4
I traded my previous tractor to the dealer also as the tax savings (only paying on the difference) was more than I could get in extra dollars selling it outright. It is very hard to sell a used tractor right now due to the economy and the "cheap" financing on new tractors. There are a lot of deals out there on used tractors due to that fact. Just check out Craigslist to see all of the tractors for sale.
I would go with turfs. I had r4's on my previous tractor (B3030) and now have r3's on my current tractor (GL3240) and the turfs are just as good in the snow, maybe better, than the industrials were. The industrials did a number on any finished lawn area they crossed and the turfs are much friendlier. With any tire you need to be careful on finished lawn and try not to use FWD.
Now, if you plan to go into a lot of mud then the r1 farm type tire would proabably be best as the turfs turn into slicks in heavy mud.
   / Going to Sell The B7510. What's It Worth? #5
The B7510 was introduced in 2004. What year is yours?
Is it hydrostatic or gear?
I think mine is a 2005 - hydrostatic. Most of the dealers here don't look at the year but moreover the model and hours.
   / Going to Sell The B7510. What's It Worth? #7
I'g go with 4 AGs.
Front Turfs will spin and tear up the ground.
   / Going to Sell The B7510. What's It Worth? #8
Turfs your probably be fine, buy for $300 for another set is a great deal. My dealrs said the same thing and i am debating on it too. I think i will definitly get a set when i purchase a MMM. Right now i still have a lot of landscaping, tree removals, retaining walls and so on to do...
But i think you are on the right track and i would do it! Sounds like you know what youe needs are and how to get it done!
   / Going to Sell The B7510. What's It Worth? #9
*I'd rather the more aggressive R4's for snow removal. Because I'm primarily doing mowing chores, though, maybe I'm stupid to consider R4's. One thing worthy of noting is that I see a few mild cuts and bruises on the surface of my current turfs - nothing compromising or deep for concern, but the R4's will hold up better when I start future projects. One dealer quoted me an additional set of turfs and rims for the BX for $300. Should I just consider getting turfs and an additional set of R4's for later, if needed?
* then go with AGs.
   / Going to Sell The B7510. What's It Worth? #10
The average trade-in value (what a dealer would give) for that 2005 7510HSD is about $6000, not including the FEL and the other stuff you mentioned. The average resale value (what dealers get on resale) of the tractor alone is about $8200.
Well, thanks for all the replies. I don't thing AG tires are an option for me with 85% dedicated mowing. They'd really do my lawn in. One of the reasons I'm going to the BX is for mowing quality.
As for the R4's for $300, they are from a different dealer that I was contemplating buying the tractor from, but they turned out to be more expensive since I'd have to sell my current tractor outright - and that's just because I'd have no tax advantage when buying outright. I'd have to sell my B for $12,000, and that doesn't seem possible. So, I doubt the dealer will sell me R4's for $300 if I'm not buying the tractor from him. I'll try though because the dealer I am buying the BX2660 from quoted $800 for the R4's. Ouch! I won't do it for that price.
   / Going to Sell The B7510. What's It Worth? #12
$800, thats insane! I went to another dealer that i have never been too and they had a set of turfs sitting in the corner and asked how much and they told me $300. This was after i aready had my machine from a dealer that i never purchased from... Maybe i should go price the 60mmm deck and turfs and maybe spend the money now just incase prices go up. I just wont use it for another year or two and i kindof dont want it sitting around...
Well good luck with your purchase.
   / Going to Sell The B7510. What's It Worth? #13
The B7510 is a great little tractor. :confused:Its not that much larger than
a BX. If your going to lose a bunch of money on the trade, I'd keep it!
   / Going to Sell The B7510. What's It Worth? #14
I traded in my 5 year old B7500,hst,302 fel,curtis cab. It had 700 hours, the machine was in very good condition with the exception of a bad front axle seal. i got $8000. in trade toward my 3030, the dealer had the machine out front the next day for $10000,
   / Going to Sell The B7510. What's It Worth? #15
I really dont know of the b7510 to compare, but the bx is easy enough for anyone to use, very user friendly, like a lawn mower. This is probably his issue.
   / Going to Sell The B7510. What's It Worth? #16
I recently went through a bought of insanity with a possible trading up. My B7510 (with LA302 and 60" mowing deck) has 210hrs and is in great shape. I was offered between 10,200 and 10,800 as trade in toward a larger tractor. In the end I decided it was dumb of me to do it and very glad I did. My tractor is payed off and fits 90% of my uses. It 'ain't broke but I tried to fix it.
I agree... INSANITY... but since I bought the B7510, I've always considered it to be a bit more than what I need on 1-3/4 acres. I was set on the BX originally, but at the last minute after talking to my Dad, I went "B". I have a nasty habit of always thinking "Bigger is Better". Now, most of my tractor seat time is mowing, and then snow removal in the winter. Still, I do a fair amount of loader work with dirt, mulch, moving things, etc., so I won't live without a FEL. For my wife and son to use, the BX will be better, although it will take awhile for me to dare to let them in the seat.
I like on the BX over the B because of the suspended mower. My bumpy yard hates the ground contact type of the B. The height adjustment and maintenance is easier on the BX. Taking the deck off the B is a chore that always requires the loader to be on. No matter how, i never find the way to sneak it out without the loader lifting the front end. The BX turns tighter and is more compact and lower to make my son more comfortable mowing in a few years.
As my previous posts read, my B rips up the grass on turns and under my trees. I like a nice clean manicured yard, and the B is less than stellar in this department. I'm on my second B (a 7500 and a 7510), and neither made me excited in the mowing department. I went fromn turf tires to bar turfs, and neither one work any better. They cut terribly, unless I turn very slow and not half-way tight. That's why I have been looking for a nice used gardern tractor. But for a little more than what a good used dedicated garden tractor is going for, I can add that cash to my trade, and go with one single compromised machine (a BX) and eliminate taking storage space I don't have, having extra repair bills on another machine, and getting eaten out of house and home with gasoline bills over diesel.
I still think that the few grand it will cost to go to the BX could buy a nice tiller and some other implements for my B, or the front snow blower, but I am sure by fall, or next spring, I'll be back at the same point... wondering if I should trade to a BX.
The BX will do anything I curretly do, and the 1-3/4 acre I maintain is peanuts compared to those here on TBN that use their BX's for 5 & 6 acres. The loader on the BX barely compromises over the B, the mower on the BX is still 60" - only a better deck (suspended), and the only other advantage of the B beisides ground clearance is the 3pt litf capacity - which I'll never need 1,000 pound for. comprom
I know it's not happening for free, but I think the BX is the best compromise.
Go ahead everyone... now's the time for thoughts and recommendations. I haven't bought the new BX just yet.
   / Going to Sell The B7510. What's It Worth? #18
OH NO!!! Don't get me wrong in your particular case it might be a better choice. Probably a better choice given the tasks you listed. In my case I have to have a machine that can go in the woods and haul a few dozed sawlogs. I thought I would need a bigger tractor when all I needed was different tires that are loaded. That is my particular case. Yes the B7510 is kind of big for mowing and kind of small for hauling large pieces of wood. I realized that it was a good mid-ground for me. I never used a BX but I think it is a small tractor that can also mow grass. It is not just a large lawnmower that will do some other stuff. Put an add on craigslist and see if someone would like to trade a used BX for your B7510. I just traded tires with someone that same way.
   / Going to Sell The B7510. What's It Worth? #19
I would keep the 7510, but I think the bx cuts grass better. You will loose 2k on a trade.
   / Going to Sell The B7510. What's It Worth? #20
But will get a brand new shiny bx for the whole family to enjoy and use!
MANIFOLD TRAILER (A58216)
MANIFOLD TRAILER...
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
Zero Turn Mower (A59231)
Zero Turn Mower...
2013 Ram 1500 Crew Cab Pickup Truck (A59230)
2013 Ram 1500 Crew...
UNUSED KJ 11' X 19' ALL - STEEL CARPORT (A52706)
UNUSED KJ 11' X...
