Opinions on trucks
Status
Not open for further replies.
/ Opinions on trucks #321
In an interesting reversal of tradition for trucks, the premium engine for the light-duty F-150 will be a V-6. The new rear-wheel-drive version of the 3.5-liter, six-cylinder EcoBoost gasoline turbo direct-injection motor will occupy the top slot.
Yeah, now I have to worry about replacing a $1500 turbo every 50,000 miles and get major turbo-lag off the line when I am trying to pull a load from a stop or up a hill. That motor will be sack-less when not building boost so all low-end grunt is gone. No Thanks! A supercharged engine makes sense in a truck but a turbo-charged engine does not.
A 5.0l V8 with 400hp/400lb.ft. would be impressive but I highly doubt it will come from Ford, one thing they can't do right is build a small displacement powerful motor. They still don't have a motor making at least 1hp per cubic inch, not even the big V10 6.8l (362hp-415cu.in. = 0.87hp per cu.in) or V8 5.4l (330cu.in-320hp = 0.94hp per cu.in.). Dodge 5.7l (390hp-345cu.in 1.13hp per cu.in) and Chevy 6.2l (403hp-378cu.in = 1.06hp per cu. in) have done this and the HEMI has been doing this since 2002. It's time for Ford to catch up.
/ Opinions on trucks #322
I guess you have never driven a diesel or anything with a turbo? Both my PowerStroke 6.0's and even my Dmax spool up quickly. My old 7.3 was a little slow but was plenty powerful.
I am sure Ford will find away to make it a non event. The 6.4 with its inline turbos is seamless. I have driven a few on test drives and never noticed any turbo lag.
As for the Hemi, I bought into the hype and funny commercials when I had mine. My 2500 4x4 Hemi was a gas hog that lacked low end grunt. Had plenty of power around 3,000 rpm and above. Boy, what a disappointment. Yes, like I have said before it makes good power, just in the wrong place for a truck engine. It should have never found its way into a truck. The big displacement GM motors, the Ford 5.4 and V10, and the Toyota 5.7 and Nissan 5.6 all out shine it as far as desirable power in a truck. What Dodge should have done was build upon the 5.9 360 cu inch or just built a truck motor. I would have no envy of a Hemi in a truck, in a car like a new Challenger or Charger, yes. But not in a truck.
Chris
/ Opinions on trucks #323
Turbos belong on DIesels, not gassers!! There are rare exceptions, like the 3.8L buick, but still, I stand by my statement. :)
/ Opinions on trucks #324
I guess you have never driven a GAS powered turbo charged engine... A diesel makes so much compression and has such a large displacement that the turbo is spooling even at idle and making a few pounds of boost. Even a variable vein turbo will have trouble spooling on a small 3.5l V6.
The HEMI makes 225lb.ft of torque at just 1600rpms and over 350lb.ft. torque at just half it's rpm range. Where's the Ford and GM dyno? Dual plugs per cylinder, high compression and hemispherical heads all lead to good low end grunt. Granted a larger displacement motor should make more torque at lower rpms but if you really need more than that, get a diesel or get a lower rear end gear. I bet your 2500 had tall gearing like 3.73 instead of the 4.10 or 4.56.
/ Opinions on trucks #325
As I said in a previous post, first gas motor for me since 89. I like it so far and it is doing admirably (I guess) for brand new, out on a 7 mile stretch of interstate that I travel each day... Anywhere from 16 to 17 and change, When I go into Southbridge, slow and hilly small city,,, it drops immediately to 12 and below to 9 depending how traffic is moving. Reading the book, this is normal... I got on it once from a dead stop.. It'll go quickly, but how fast is quick when all you ran were diesel pick ups, diesel tractor trailers and diesel tractors for so many years? I'm not going to mess with it,, No computer enhancements, no hot rodding, nothing... Leave it bone stock, drive it, and enjoy it for a change.. And, Builder is right... I am partial to Dodge, like them, even though this month I tried GM's-Chevies, and Ford 150's, and still stayed with Dodge,, We had this discussion months ago over DPF systems and Dodge's, and I said then and maintain today, one Dodge web site doesn't speak for all,,, I've been reading a couple of GM/Chevy pick up sites and it is the same thing... One site has mechanical problems to deal with and the other, paint and odd things to deal with,, Just the nature of the beast and which site hits your fancy...
That's my favorite thing about my truck. No hot rodding necessary. I know I have 360/650 and a 6 speed Allison trans. I never felt that my previous trucks of other brands had enough power or drivetrain.
/ Opinions on trucks #326
From PickupTrucks.com:
By late 2010, the new standard engine for the F-150 will be a 5.0-liter, four-valve, naturally aspirated V-8, developed under the code name "coyote." This eight-cylinder engine (described as having "huge heads") will be shared with the new Ford Mustang. Power figures are said to be approximately 400 horsepower and 400 pounds-feet of torque. Fuel economy is expected to be comparable to the current 5.4-liter engine.
Great, but as always, years behind the competiton in power wars. Ford's almost always 2nd or 3rd in available power.
Ford's next diesel better be 400HP right from the start. If they come out at 350-375, I think they're making a big mistake.
In an interesting reversal of tradition for trucks, the premium engine for the light-duty F-150 will be a V-6. The new rear-wheel-drive version of the 3.5-liter, six-cylinder EcoBoost gasoline turbo direct-injection motor will occupy the top slot. Ford has officially said the EcoBoost engine will arrive next year with improved fuel economy and low-end torque with a broad, diesel-like torque curve through most of its power band. Our sources say it too will be rated at approximately 400 hp and more than 400 pounds-feet of torque. Gas mileage is expected to be at least 23 mpg on the highway.
I'd love to see it. Might put me back in a Ford, although I can't imagine only having 400 ft lbs when I have 650 in a stock DMAX right now!!! :eek:
/ Opinions on trucks #329
Looking forward to the year 2016 when trucks must get over 30 mpg, makes me wonder if the bodies will be made of styrafoam.
Very interesting! By the time I am ready for a new truck I hope that the bugs in the new designs will be worked out. I'd sure like to get 23 mpg in my truck!
/ Opinions on trucks #332
They're still all to big.
It depends what your needs are. If you need power to tow, maybe not too big. Maybe not big enough.
I've got a '95 Chevy 1500 5.7L. I went to CA last month, This time towing a 2-horse slant trailer. Going North 35, through the Metroplex, went up 287 to Amarillo, out 40 West through New Mexico (through Albuequerque), Arizona (through Flagstaff-near Grand Canyon), CA High Desert/Mountains (Barstow, 58 to Tehachapi), 46 to the Central Coast.
My truck did fine. Had to put it in 3rd (45mph) up those grades. But of course, all those 2500's, 250's and up that were towing, passed me on those grades with ease.
I Need A Bigger Truck!
Saw this beautiful Chevy Kodiak pass me up with big horse trailer, West of Needles, CA. That's my dream truck!
Up here in Canada, we have trucks that run on baby seals. I put a pile of them in my bed and then club them as necessary. Fuel efficiency is measured in MPS - miles per seal. ;)
/ Opinions on trucks #336
Oh yeah ..........1995 was a great year for GMC.......I still have one that has 270,000+ and going strong. went to Colorado from Arkansas in it last September..........
/ Opinions on trucks #337
I got over 202,000. On that trip, coming back to Texas, just ~30 mi west of Amarillo, hit 200,000. Been watching the mileage all the way. It was at night. Pulled on the service road and took a picture. Do y'all get excited as I do when yours hits big round numbers?
/ Opinions on trucks #338
It's a good thing the PETA fruitcakes don't read this forum or they would have the moderators lock out this thread.
You sure do like to stir things up Canoe! :rolleyes:
/ Opinions on trucks #339
Yep, it's neat to see that little army of like numbers on the dial.
/ Opinions on trucks #340
Imagine that.....a "chebbie" going over 200,000 miles whilst pulling a 2 horse slant.
Not bad......;)
Status
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
ROLLING TOOLBOX (A62131)
ROLLING TOOLBOX...
PORTABLE SAND BLASTER (A62131)
PORTABLE SAND...
UNUSED WOLVERINE LL-12-78W 78" LAND LEVER (A62131)
UNUSED WOLVERINE...
2004 International 8600 Tender Truck (A63118)
2004 International...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
