Please Help John Deere L120
/ Please Help John Deere L120 #1
Sierrasun
I would really appreciate any expert advice. This is what we have done thus far. Mower will not start...we replaced the fuel filter, fuel pump, air filter, and today we bought a BRAND NEW carberator. It still WILL NOT START. Could someone please give advice on what to do now...we are just stumped.
Thanks very much in advance.
/ Please Help John Deere L120 #2
Sierra, does this use the Kohler Command engine, say 20-27 HP?
If so, start with basics (if not Kohler, a lot still applies):
1. Got spark?
2. Got compression?
- if not, pull rocker box cover(s), may have broken or bent push rod, or a flat cam
3. Got fuel in carb?
- If not and if it has a fuel solenoid at bottom of carb, make sure it is getting voltage and operating OK, should hear a click when turning key on before start position
- check fuel pump operation by removing line to carb at pump, removing impulse hose from crankcase, blow/suck...blow/suck to operate fuel pump (the hose in your mouth should be dry/safe/no gas, only operates the air side of fuel pump diaphragm)
If you have spark, compression, and fuel and it still does not start, you have a puzzler.
RavensRoost
/ Please Help John Deere L120 #3
Are you running fresh fuel? As in just bought it yesterday. What does the spark plug look like?
213137 (A64276)
213137 (A64276)
11.2-24 Tires - Set of 4 (A68134)
11.2-24 Tires -...
2025 60 Gallon Poly Diesel Tank w/ 12v Pump, nose, Nozzle and Pump (A64557)
2025 60 Gallon...
2008 Generac SD100 T3 125kVA Standby Diesel Generator (A66734)
2008 Generac SD100...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
CATERPILLAR 249D3 SKID STEER (A65054)
CATERPILLAR 249D3...
