Another JD vs Kubota question
/ Another JD vs Kubota question #21
The machine with the backhoe attached came out in the high 16K and add on some taxes.
...I had anticipated JD being at least 2k more.
So if I want the 3 pt. hitch for the Kubota the difference is really around $700 I am guessing.
With all this being said, would you consider paying the extra for the John Deere?
Or do you think Kubota has a better quality machine?
Does anyone know what differences there might be?
Thanks again for the help you guys bring.
I had just recently gone through the experience of choosing between JD & Kubota. I ended up with the orange because of price and dealer service. Long story short, after all of my haggling, I got the BX25TLB (I think $200-$300 3 point, included) with canopy and rear work light in the low 16K. I bought out of State so there was no sales tax, I also got the $300 delivery charge waived.
I tested both BX25 and JD2305. After having the BX for almost 3 weeks now and a little over 35 hours seat time, I realize additional preferences orange over green:
1. $2000 price difference. JD attachments are more expensive.
2. BX has foldable rops. I like the wide and tall rops too.
3. Nice big gas tank hole, nice location.
4. Bright usable halogen head lights.
5. FEL hoses located in a vulnerable location, susceptible to damage.
6. Filters underneath the JD not in a good spot. I just don't like the clearances underneath the JD.
7. I really like the pedal on the BX much more than the JD. I thought I prefer the side by side but after using it for a bit I prefer the BX pedal.
8. There is talk about JD tail lights not so well positioned, you will bang em off or need to buy a protector for it.
9. My personal opinion, the BX backhoe has more power.
A couple of things could be designed a little better on the BX: the dash, digital tach numbers should be LARGERwith a separate hours meter.
I can't think of all of the things I like better about the BX but I will post it when I remember. It comes to mind when I'm in the seat.
Oh by the way, the dealer sent me a free can of orange paint and a nice collector series BX tractor model too because I asked.
/ Another JD vs Kubota question #22
I just remebered something else, the seatbelt is much more user friendly being a retractable one on the Kubota. The JD has a wierd receptor for each buckle end on each side. It's messy looking.
/ Another JD vs Kubota question #24
Both of the tractors that you are looking at are great machines. My personal choice would be the Bx, as I have owned a Bx23TLB. It was quite the tractor that could do it all, I was so pleased with that machine and the ability to do any task put in front of it. Oh, It was my understand and I have two Kubota's that the
*Three point hitch came with tractor, You need to make sure, ask Kubota.com.
DevilDog
*Tha's true up till the BX25 came out .
/ Another JD vs Kubota question #25
My .02 on the pedal issue --
I have a JD 325 with the side by side pedals, and a Kubota B3030 with the rocker pedal.
In 8 years with the JD 325, I've pushed the wrong pedal exactly 2 times in a moment of panic when it really mattered. Thankfully the damage was only to the tractor and the fence (and my pride as I lay on the ground).
With the Kubota B3030, I've never pushed the pedal the wrong way. And thank goodness, because the B3030 would cause a lot more damage than the 325.
In a moment of panic, I can't say for certain I'd grab the right pedal on the JD as I'm fumbling for the brake/reverse/forward. Frankly, as I sit here at my desk, I can't remember if it's the RIGHT pedal or the LEFT pedal to go forward/reverse.
In a moment of panic, there's no doubt in my mind that I WOULD push the pedal the right way on the Kubota with the rocker pedal. And as I sit here at my desk, I'm absolutely certain which direction to rock the pedal to go forward/backward.
Most of the time -- actually, almost all of the time -- it doesn't really matter to me. But in a moment of panic, I've found the Kubota pedal to be safer and more intuitive.
/ Another JD vs Kubota question #26
On my BX2350 with the two separate fwd/rev pedals, I rarely use the rev pedal. I just pull up on the fwd pedal with the toe of my boot. It's also much easier to feather the pedal this way as opposed to using your heel.
/ Another JD vs Kubota question #27
Thank You, I figured maybe I was wrong when I got rid of my John Deere 335 for a BX. I just hated them pedals. It wasn't the forward and reverse it was the position of the pedals and having to hold it down,put my leg to sleep. I have no problem with the layout on the BX. My 3130 has the rocker arm and it's about as Perfect as any I have driven.
1984 Cheetah Chassis Corp 53ft. 32 Ton T/A Container Chassis Trailer (A61568)
1984 Cheetah...
Solesbee Hydraulic Thumb (A61166)
Solesbee Hydraulic...
Deutz Diesel Engine (A61568)
Deutz Diesel...
UNUSED WOLVERINE MSG-11-44W 44" HYD STUMP GRAPPLE (A62131)
UNUSED WOLVERINE...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63118)
2023 Kubota L3560...
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
